Author Topic: Best way to split bbs rx2s? Update!!!  (Read 9300 times)
Offline murraymint
« on: 01 September 2012, 19:53 »
As above what's the best way to split rx2s? And where can you get new bolts?
Josh
« Last Edit: 10 September 2012, 19:25 by murraymint »
josh
Offline Screech16v
  • MK3 20vt AGU
Re: Best way to split bbs rx2s?
« Reply #1 on: 01 September 2012, 20:06 »
Put the spline drive socket into the bolt and give it a good clout to break the seal of corrosion,crack them all off and use airgun or drill to unscrew or youll be there forever did this and every bolt came out intact,make sure to run the m7 tap through all the threads to clean them ,on reassembly i reused the original bolts with thread lock   :smiley:
« Last Edit: 01 September 2012, 20:25 by Screech16v »
Offline GOLF-MK3-GTI
« Reply #2 on: 01 September 2012, 20:08 »
You can get new bolts from eBay,
But you need to match them with the current ones you got,
Some Marked M7 and some Marked bbs VS
Offline twotwofour
« Reply #3 on: 01 September 2012, 20:54 »
I'm about to strip some split rims, I've done a bit of searching for info and found myself on the Wheel Whores forum. In the split rim section there is a couple of stickies threads about stripping, refurb, rebuild and suppliers.
Take a look, although some of it is a bit OTT
http://www.wheel-whores.com/forum/viewforum.php?f=7&sid=83401459700b11c6d787fc70df86056a
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline murraymint
« Reply #4 on: 01 September 2012, 21:25 »
Cheers bud, good shout with the 7 tap, did you round off any bolts? Because that's my nightmare!
Ideal cheers bud, il keep an eye out for those markings?
I did have a quick look on there, will look again. What wheels are you splitting? Will be good to hear how you get on
josh
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 01 September 2012, 22:43 »
No mate all bolts came out no problem,i heard they are titanium so drilling one out would certainly be a challenge,good luck  :wink:
Offline murraymint
« Reply #6 on: 01 September 2012, 23:04 »
That should help them not rounding off then  :cool:
josh
Offline Ess_Three
« Reply #7 on: 01 September 2012, 23:13 »
They just shear if you get too rough with them!
Then you do have problems...
..but gaining motorcycles.
Offline murraymint
« Reply #8 on: 01 September 2012, 23:14 »
Awesome! Lol, any tips?
josh
Offline twotwofour
« Reply #9 on: 02 September 2012, 06:41 »
Mine are the same as these although I didn't buy this set
http://forums.vwvortex.com/showthread.php?5793982-FS-16-quot-STAGGERED-3-PIECE-VOLK-GR-C-s
I doubt the bolts will be titanium as its an expensive material, more likely 12.9 steel, chrome plated from new, replacements will be around £100 for a full set. If they all come out ok you could have the bolts refinished and chromed.
The originals will have loctite on them. Make sure the socket fits really well, use heat and it well help release them.
Titanium and stainless versions are available as replacements but they are harder materials, more likely to damage threads and if not properly lubricated could easily get stuck and would be a nightmare to drill out.
