Author Topic: Fault codes ahoy!  (Read 3188 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Fault codes ahoy!
« on: 20 August 2012, 16:45 »
Just picked these up off the Golf, I'm assuming and hoping they are down to the clocks being changed?
Address 01     -------------------------------------------------------
   Controller: 06A 906 018 CG
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
Address 17     -------------------------------------------------------
   Controller: 1J0 920 926 A
   Component: KOMBI+WEGFAHRSP VDO V02
10 Faults Found:
00771 - Fuel Level Sensor (G)
            30-10 - Open or Short to B+ - Intermittent
01039 - Coolant Temperature Sensor (G2)
            29-10 - Short to Ground - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
00779 - Outside Air Temp Sensor (G17)
01128 - Immobilizer Pickup Coil (D2)
01176 - Key
            07-10 - Signal to Low - Intermittent
01314 - Engine Control Module
            49-10 - No Communications - Intermittent
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
01336 - Data Bus for Comfort System
            49-00 - No Communications
Address 19     -------------------------------------------------------
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
5 Faults Found:
01331 - Door Control Module: Driver Side (J386)
Now they've all cleared off apart from this one which seems to come back all the time, it this cos I still have an immo2 CCM and not the immo3 version?
1 Fault Found:
Offline jamie1989
Re: Fault codes ahoy!
« Reply #1 on: 20 August 2012, 17:27 »
Haha beat my list mate, Worse iv seen is about 3 or 4 codes  :evil:
Best one is Engine warranty VOID max speed exceeded lmao  :laugh:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 20 August 2012, 17:49 »
That is an awful lot of codes. I'd probably drive to the scrappy now...save you getting a tow  :lipsrsealed:
Offline dan2252
« Reply #3 on: 20 August 2012, 21:51 »
id say most of them are due to stuff been unplugged when you did clocks or whatever, try clearing them all and seeing what comes back,
MK4 golf 1.8 turbo agu :)
Offline golfyste
  • Project track car
« Reply #4 on: 20 August 2012, 22:59 »
With a little ":)" at the end haha
Offline GTi_James
« Reply #5 on: 22 August 2012, 09:32 »
isnt that pretty much all the sensors?  :shocked:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 22 August 2012, 11:22 »
Found the problem. All the codes apart from the last one are down to changing the clocks over. The last code is my fault for not clearing out the can gateway soft coding. It was the same as my old clocks so I just left it as it was but you need to clear and re enter the coding to get it to re sync. It was stalling straight after I started it up too but all sorted now
