Author Topic: How much will a AGU take?  (Read 4113 times)
Offline jamie1989
Re: How much will a AGU take?
« Reply #10 on: 17 August 2012, 11:12 »
Thats 300lbs of torque out of window then!
Im back up Wednesday with Nick on my stage 2 custom AGU k03s.
I want around 245-250bhp and around 260-280lbs based on this thread.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Chris#101
« Reply #11 on: 17 August 2012, 12:38 »
from a k03s ? :lipsrsealed:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline dom
  • Back in a Mk4
« Reply #12 on: 17 August 2012, 12:42 »
That's a tad optimistic :grin:
Offline jamie1989
« Reply #13 on: 17 August 2012, 12:53 »
We will see.
Its not just from a K03s  :wink: and WITHOUT water meth.
Its a custom map.
Offline dom
  • Back in a Mk4
« Reply #14 on: 17 August 2012, 12:58 »
We will see.
Its a custom map.
No matter what supporting mods your adding, the turbo will be the limiting factor and you'll struggle to see the figures you've quoted with a KO3s :undecided:
Offline Dalo Harkin
« Reply #15 on: 17 August 2012, 12:59 »
with supporting mods you are right on the limit of the turbo at those figures
Offline jamie1989
« Reply #16 on: 17 August 2012, 13:00 »
Same turbo same spec as what I have is running 260bhp with Nick when I was there, He actually took me in it.
The only difference is hes got WMI.
Chris on here was runnning the exact same spec (I dunno what exhaust) but running 248bhp 270lbs+?
Im not saying I will get these figures but I hope to be close as.
Offline jamie1989
« Reply #17 on: 17 August 2012, 13:05 »
Heres Chris's hope he doesnt mind
Offline Prawny
  • R-tech power!!!
« Reply #18 on: 17 August 2012, 13:14 »
These cars are exceptional though, and not the norm. the 260bhp one you speak of is TingTongs, he works there, and the WMI allows LOADS of timing to be added. Special cars indeed compared to those you drive around in every day.
Also, a ko3S at 250bhp won't last very long at all.
Sensible figures are 230-235bhp and 270lbft, they can produce this year in year out and don't fall apart. Anything more than that and you've created a time bomb.
Offline dom
  • Back in a Mk4
« Reply #19 on: 17 August 2012, 13:19 »
[/thread]
