Author Topic: How much will a AGU take?  (Read 4112 times)
Offline tom-gardiner
« on: 16 August 2012, 18:50 »
How much power will the standard internals on an AGU take roughly?
Thanks guys :)
The Clio didn't as it's naturally aspirated and French  :sick:  :laugh:
My Project Thread ;)
Offline dom
  • Back in a Mk4
Re: How much will a AGU take?
« Reply #1 on: 16 August 2012, 18:57 »
It's torque you should be worrying about, not bhp. I wouldn't want to be running any more than 300lb/ft on standard internals....rods will be bent going much higher than that.
« Reply #2 on: 16 August 2012, 19:00 »
stage 2 will be fine then even with a ko3s?
Offline dom
  • Back in a Mk4
« Reply #3 on: 16 August 2012, 19:01 »
Yeah, should be fine :afro:
Offline dan2252
« Reply #4 on: 16 August 2012, 20:36 »
the experts say 300bhp so stage 2 will be fine!
MK4 golf 1.8 turbo agu :)
Offline Toby
  • Car - less
« Reply #5 on: 16 August 2012, 22:00 »
mine was runnin 309! no probs! standerd internals, and that was., stage 3?  :undecided:
Currently down under
Offline jamie1989
« Reply #6 on: 16 August 2012, 22:03 »
350lbs of torque Iv been told is pushing ur luck.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Chris#101
« Reply #7 on: 16 August 2012, 22:20 »
All depends how healthy your engine is :wink:
You can't just say a figure
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 16 August 2012, 22:26 »
Offline Prawny
  • R-tech power!!!
« Reply #9 on: 17 August 2012, 10:41 »
even 300lbft is pushing your luck. Remember these engines are getting old now!
As said, it's torque not power that kills rods, so map accordingly.
I currently have a ko4 hybrid capable of 340bhp / 300lbft, but it's mapped very safely making 300bhp, with only about 260lbft, which it holds right across the rev range. Feels incredible to drive, and the power just keeps on coming and never stops, but it's low torque, and rod safe.
People have bent rods just at Revo st1 on ko4 cars....
