Author Topic: Think it's time to admit defeat  (Read 6466 times)
Offline Dogbot
Re: Think it's time to admit defeat
« Reply #30 on: 15 August 2012, 18:45 »
CL cluster FTW, or piggy back off the airbag light
Or if you can't find a CL one, tape it up they can't remove tape...
« Last Edit: 15 August 2012, 18:47 by Dogbot »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #31 on: 16 August 2012, 01:01 »
I'd be checking for diagnostic fault codes at this point, you might have some ABS issues that need attention.
Offline stainesy
« Reply #32 on: 16 August 2012, 09:13 »
I'm gona check my brake lines today specialy the rear as when I bled the breaks the rear drivers side one had sh!t loads of air in it.
Offline Edwh0re
« Reply #33 on: 19 August 2012, 08:08 »
Didn't you already say you had an issue with the Master Cylinder?
If my knowledge of the mot is correct, the new system will instruct the tester to look for a functional abs light on yours.  It takes a lenient tester to turn a blind eye to one that has been piggy backed off of the airbag or oil pressure switch, as the lights generally illuminate together and then go out seperately on a properly functional one.
I had the abs light up on mine, turns out that I had disturbed a sensor when swapping over the suspension.  I would get it code read to see what codes it throws up with the abs and then you are pointed in the right direction.
If you were closer, I would lend you a wiper motor to get yourself sorted out, you shouldn't have to pay any more than a tenner for a wiper motor and mechanism from a breaker/classified, and it is a wiper arms off/scuttle off/3 bolt and one cable connector job.
Offline stainesy
« Reply #34 on: 19 August 2012, 13:16 »
I already bout new wiper motor. Hasn't arived yet. But I don't need it now as car is going to be broken or swapped for a set of Porsche wheels and adaptors for my new car.
Offline DUBboi12
« Reply #35 on: 23 August 2012, 21:24 »
Parts of you car still live on  :smiley:
Offline stainesy
« Reply #36 on: 23 August 2012, 21:35 »
oh no so you have ripped her feet off and pullered her eyes out  :cry: :grin:
wheels look good. are they my headlights to? or are they yours. think i remember you already having them headlights actually  :undecided: cant remember
Offline DUBboi12
« Reply #37 on: 23 August 2012, 21:40 »
Yeh they are mine bud, wheels splitter coilovers and a few other bits come off it :smiley:
Offline stainesy
« Reply #38 on: 23 August 2012, 21:49 »
ah right yeah cool. bet that splitter was a b!tch to get off. that had really good clips on it
