Author Topic: Just got my milltek....Few questions.  (Read 2810 times)
Offline tom-gardiner
« on: 13 August 2012, 19:23 »
Just fitted a Milltek cat-back non-res with 4mo style tips. really impresses with build quality. I have no other mods and it pops and bangs quite alot on pull away and when changing gear. Should this be happening?
I have also just ordered a milltek downpipe and de-cat and piperX panel filter. Will this be too loud for a daily with the non-res?
While we are here (i know this next question has been covered a million times before but im on my phone
and being lazy) if i have the full turbo back, panel filter with smoothed air box and forge 007p will i need anything else to go for a stage 2 remap?
Thanks for any advice guys :)
The Clio didn't as it's naturally aspirated and French  :sick:  :laugh:
My Project Thread ;)
Offline jamie1989
Re: Just got my milltek....Few questions.
« Reply #1 on: 13 August 2012, 19:42 »
Whats your engine code?
Youl need a decent fmic for stage 2 nowadays and a forge actuator to keep the waste gate closed with high boost.
How wide is the exhaust mate? Stage 2 would ideally need 2.75" or 3" from turbo back.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
« Reply #2 on: 13 August 2012, 19:44 »
Engine is AGU. Was thinking FMIC wasn't sure if was needed tho. Think the milltek is 3" downpipe and 2.75" for the rest
Offline dstv
« Reply #3 on: 13 August 2012, 20:14 »
what does a  forge actuator look like ?
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline GTi_James
« Reply #4 on: 13 August 2012, 20:23 »
That's the exhaust I want but torn between that and a turbo back like wazzzer
Exactly how loud is loud though?
Offline turbokid23
« Reply #5 on: 13 August 2012, 20:32 »
I've got the same 3"downpipe and miltech but my rear is r32 and it's loud bangs and pops it noisy want a silencer put in
Offline golfyste
  • Project track car
« Reply #6 on: 13 August 2012, 20:55 »
Miltek is 2.5" cat back
A fmic would be best and Also a bigger maf, injectors and might as well get a k03s  :evil:
Offline wolfie1981
« Reply #7 on: 13 August 2012, 21:38 »
i have a full miltek non rez system on my 1999 agu with de-cat not loud at all.
 popping is good by the way lol :wink:
« Last Edit: 13 August 2012, 21:42 by wolfie1981 »
Offline jamie1989
« Reply #8 on: 14 August 2012, 00:16 »
You will need a k03s end of. Stage one will push the little k03 to 200bhp that it!
You can throw what you like at it youl struggle to make anymore gain.
AGU with K03s, THS fmic, 3inch or 2.75inch turbo back exhuast an forge 007p your laughing.
Then once thats done go further with forge actuator, calibra injectors an VR6 MAF.
  :cool: Thats my current route atm.
Offline Prawny
  • R-tech power!!!
« Reply #9 on: 14 August 2012, 08:35 »
Jamie, 2.75 or 3'' turbo back just isn't needed on a ko3S, 2.5'' pipe work doesn't become a restriction until over 300bhp really. I'm happily running 300bhp on my car with a 2.5'' milltek catback and it flows brilliantly.
Is there really much to be gained from doing the injectors and MAF at st2 keeping the ko3s? the turbo is near on maxxed out anyway with the stock injectors and MAF, so the gains can't be THAT big can they?
