Author Topic: ok so after trying this & checking that, I think its time I had it looked at.  (Read 2769 times)
Offline JimBR
17705 is pretty infamous. I had it and it was my PCV system leaking. I replaced all the hoses with creation motorsport silicone ones and its been fine since.
Are all the hoses under the inlet oily?
Offline Nino
if your really stuck im sure if you arrange with me and jamie we will come and have a look at whats going on if your prepared to drive up and meet us and if you do decide to fit a catch can and you need help give us a shout as long as you come up il help you get it fitted  :wink:
To be honest It would be nice If I could drive up to you for you both to take a look im guessing you know what to look for and may just look and go thats it right there lol btw where u based?
Current - MK6 GTi Edition 35
Offline Nino
I did check that pipe but it looked fine  :undecided:
Offline cullygti
im in ebbw vale and jamie is in aberdare mate  :smiley:
Offline Nino
yor both roughly a hour away drive then, i'll keep trying a few things first because I'll have to pop up a day we are all off work  :grin:
Offline jamie1989
Yeah anytime on weekends or evenings im cool with  :cool:
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline JimBR
Mine looked fine when I took them off, there were no obvious splits. They must have been leaking at the joints. The oily mess everywhere is a giveaway.
Offline Nino
I couldnt see any oil, althou there is some around the bottom end of my block just below the Termo area, and there is also some on the bottom of the sump near the big intercooler pipe area althou im unsure weather thats oil fromt he drive shaft as thats oily too. I took my Turbo/intercooler pipe off and looked all round it, bent it looking for cracks/holes but nothing. The PCV pipe looked almost brand new to me althou the clips holding it on are the standard *once you remove them you can't re-use them jobs* so I didn't fully remove it for inspection. Am I right in thinking thats the pipe that connects to the inlet?
Offline Nino
I just found these on Ebay althou unsure weather they would be anygood? also it says something about may not fit my engine code? AUM.
http://www.ebay.co.uk/itm/VW-GOLF-MK4-1-8T-BORA-JETTA-SILICONE-TURBO-BOOST-HOSE-INTAKE-PIPE-KIT-1999-2006-/230717415044?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b7d45e84
Offline cullygti
« Last Edit: 13 August 2012, 14:12 by cullygti »
