Author Topic: ok so after trying this & checking that, I think its time I had it looked at.  (Read 2764 times)
Offline Nino
Hey guys,
Alittle while ago I posted a few error codes I was getting..
17545
 P1137
 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17704
 P1296
 Cooling system malfunction
17705
 P1297
 Connection turbocharger - throttle valve pressure hose
I manage to fix the 17704 by replacing the Temp sender & termo but I still have the other two, So far I have done the following..
  • Changed the DV for a new strandard.
  • Changed the MAF for a new one.
  • Checked front PCV breather (looks fine)
  • Checked the pipe between the intercooler & Turbo (looked fine)
  • Looked at all the pipes/hoses I could look at but couldnt see any splits or aything/
Now I do know that my 2ndry air thingy is faultly as it sounds like a tracktor when i start her up for about 60 sec but I have been told this has nothing to do with my fault codes.
My 2 questions are, before I get her booked into Euro performance is there anything else you guys can think of that i could/should or havent tryed yet?
also am I right in thinking that the error code 17545 would be because of 17705 causing it? or will that defo be for another reason??
Thanks guys :)
Current - MK6 GTi Edition 35
Offline rio_gti
Bet there is a split in one of the vacuum hoses double check them all or even buy some new silicone vacuum host think its 3mm inside diameter and replace it all
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
you need a pressure test to be 100% sure
Offline Nino
I see can you advise on a full set to buy and wont make me skint lol?
Offline Nino
How do I do this Wazz?  :undecided:
Offline jamie1989
Fit a catch can job done less than £50.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
You need someone who knows what they're doing with pressure tests. They are also called smoke tests. See if any local garages can do it :wink:
Offline Nino
Offline jamie1989
For a smoke test go see Craig at gotboost in Bridgend I think it costs around £35 but dont quote me on that.
As above spend £5-6 on 2 meters of 3mm silicone tubing off ebay and change the vacuum pipes from inlet to fbr and recirculating valve.
The breather pipes can be a nightmare when split etc too I wouldnt bother replacing them id just fit a catch can its much cheaper.
Offline cullygti
if your really stuck im sure if you arrange with me and jamie we will come and have a look at whats going on if your prepared to drive up and meet us and if you do decide to fit a catch can and you need help give us a shout as long as you come up il help you get it fitted  :wink:
