Author Topic: Another question....  (Read 3656 times)
Blue MK2
« on: 04 October 2003, 20:44 »
Does anyone else have this rattling noise which seems to be coming from the front wheel areas?
Everytime i go over even the smallest bumps i get a harsh rattle. The car has been checked but there seems to be no problem.
It lowered on coilovers and is on a stiff setting but ive had this noise from a standard suspension setup.
Any ideas?
Offline AdamB
  • The Perfect Storm
Re:Another question....
« Reply #1 on: 04 October 2003, 20:48 »
Is it a loose wheel cap? took me a fair while to track it down to that on mine, I kept thinking it was the exhaust :-[
I don't own this anymore - I just can't be arsed to change the picture
Blue MK2
« Reply #2 on: 04 October 2003, 21:31 »
erm wheel cap? im on a set of 15's.
Offline modulater
« Reply #3 on: 05 October 2003, 14:09 »
I have a rattle on my car after replacing top mounts and putting konis on, I am thinking maybe the wishbone bushes or the balljoints need replacing, I think they are the list of things to do .
Sometimes the noise on mine sounds like inner cv joint rattle so I am gonna pop them off and grease them up a bit incase the joints have gone a bit dry from doing outer boots in the past.
Offline richandhazel
« Reply #4 on: 05 October 2003, 15:50 »
I would have thought that stiffening up the suspension would be bound to exaggerate other worn running gear components i.e as modulator says: wishbone bushes, lower ball joint.
Blue MK2
« Reply #5 on: 05 October 2003, 23:32 »
ill try greasing the inner joints up. the bushes and all other joints are in top condition.
Can anyone give me a guide when taking this on?
any other ideas let me know
Blue MK2
« Reply #6 on: 06 October 2003, 19:22 »
Just say i replace the inner CV joints how much would that cost me and is it easy to do?
Offline modulater
« Reply #7 on: 06 October 2003, 22:39 »
Its not a hard job as long as your good with the spanners, You need to undo the hubnut with a 36mm socket and breaker bar through the wheel with the centre cap off. Car on ground and handbrake on fully, its tight.
Jack the car up and put it on stands, get someone to sit in the car to apply the brakes and undo the spline sockets as you spin the shaft round. Then I always undo the strut to hub bolts to allow the shaft to be withdrawn from the hub and away from the car.
I was just gonna lube mine up with moly grease and see if it helps, I do remember last time I did the outer joint on the nearside shaft that the inner joint was a bit dry grease wise. The inners are sliding joints and if not greased up well can knock like a swine as the shaft moves in and out.
golfvr6
« Reply #8 on: 07 October 2003, 00:25 »
Spot on Mod, except its a 30mm nut? remember!  :-*
Offline Gambit
« Reply #9 on: 07 October 2003, 09:25 »
ive recently been having trouble with loud bangin after i got a set of Eibach ARB's put on
my noise comes under deacceleration, going over bumps or even reversing, mine sounds like the downpipe silencer clunkin on the tunnel
its going to get its rear mount changed next week, everything else has been checked and nobody can source the cause of the noise
its annoyin as hell
