Author Topic: WMI installs?  (Read 10036 times)
Offline ReDBull
WMI installs?
« on: 05 August 2012, 11:13 »
How many of you guys are running WMI and any chance of photos of you installs please?
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline Chris#101
Re: WMI installs?
« Reply #1 on: 05 August 2012, 11:36 »
Me  :smiley:
Manual boost control solenoid
Discreet tank
WMI injector hidden up
Pump location
« Last Edit: 05 August 2012, 11:37 by Chris#101 »
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline ReDBull
Re: WMI installs?
« Reply #2 on: 05 August 2012, 21:51 »
Nice bay dude!  :smiley:
I'm thinking of a similar set up in the boot. I take it you've dumped your spare wheel? How do you like meth?
Offline jamie1989
Re: WMI installs?
« Reply #3 on: 06 August 2012, 15:02 »
Chris is your wmi plumbed into the intercooler or inlet?
Iv seen one at R-tech his is directly into top of inlet manifold.
I to buy a kit but im clueless when fitting something like this, how easy isit?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline DunnDeal12
  • Limited
Re: WMI installs?
« Reply #4 on: 06 August 2012, 18:34 »
very easy
Offline jamie1989
Re: WMI installs?
« Reply #5 on: 06 August 2012, 18:51 »
Any good DIY's?
Offline DunnDeal12
  • Limited
Re: WMI installs?
« Reply #6 on: 06 August 2012, 18:56 »
theres a good guide on seatcupra.net i will try find it you and the one youve seen at rtech is nicks devils own direct port wmi.
Offline jamie1989
Re: WMI installs?
« Reply #7 on: 06 August 2012, 19:30 »
Awsome cheers mate.
Yeah Nick has it an its on another mk4 running 260bhp on ko3s   :cool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: WMI installs?
« Reply #8 on: 06 August 2012, 19:44 »
I think that's his missus car lol
Offline Prawny
  • R-tech power!!!
Re: WMI installs?
« Reply #9 on: 06 August 2012, 20:07 »
here's a little write up from my build thread about my WMI install, sorry if it reads disjointed, I've copied it across:
1 gallon replacement AEM WMI kit arrived, so I started making up some mounts for the tank:
An Ultra High-tech tubular clamping tank retention system developed. (absolutely, definitely, not exhaust clamps)
And the tank was hung:
Pump mounted, i toyed with a few locations, but this was the best by far:
