Author Topic: WMI installs?  (Read 10038 times)
Offline Dalo Harkin
Re: WMI installs?
« Reply #30 on: 09 August 2012, 06:40 »
Devils own states their mix is 49 water 51 meth
Offline Prawny
  • R-tech power!!!
Re: WMI installs?
« Reply #31 on: 09 August 2012, 08:37 »
i always wonder why the hell wmi is so expensive. you can make a for less than £200 with a tank.
Would you care to provide details of how you would build the boost activated progressive controller for that price?
Offline jamie1989
Re: WMI installs?
« Reply #32 on: 09 August 2012, 08:41 »
I would love to know.
Im on the verge of buying devils own meth kit.
Iv sourced meth so know where to buy it now too.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Prawny
  • R-tech power!!!
Re: WMI installs?
« Reply #33 on: 09 August 2012, 08:43 »
I paid £37 for 50 litres of meth in 2x 25L containers from a Polish chap in plymouth.
Search for methanol on ebay, and there are loads of people who buy 1000L at a time for making their own BioFuel, then sell it off by the litre for around 60p/L to make some money back.
by the time you mix it 50/50 with water, it's costing you 30p per litre of solution, so about £1.20 to fill the meth tank, and that'll typically last about the same as a tank of fuel. Very little additional cost for a considerable gain :)
Offline DunnDeal12
  • Limited
Re: WMI installs?
« Reply #34 on: 09 August 2012, 12:05 »
you dont NEED a progressive controller all you need is boost switch. its what i use i have x2 nozzles come on full spray at 8 psi
Offline Prawny
  • R-tech power!!!
Re: WMI installs?
« Reply #35 on: 09 August 2012, 12:35 »
Perhaps, but for another £100 I have a full programmable progressive controller, with a low level indicator and fault indicating LED.
From testing on mine, I've found it runs better when used progressively to start pumping at 7psi ramping up to full pump by 15psi.
Giving it full pump at anything below 12psi seems to cause a minor hesitation as it doesn't need that much fluid yet, reducing nozzle size to counter this means it hasn't got enough at the top end to cool to it's full ability.
Offline Prawny
  • R-tech power!!!
Re: WMI installs?
« Reply #36 on: 09 August 2012, 12:39 »
thats not to take away from your £200 setup, it'll still be hugely effective I'm sure, just that I'd prefer a progressive setup.
Sorry if my first post sounded a bit sh!tty  :tongue: it was early and I was grumpy!
Offline DunnDeal12
  • Limited
Re: WMI installs?
« Reply #37 on: 09 August 2012, 12:51 »
dont worry about it bro  :kiss: :laugh: but what im saying is you dont need a progressive controller to get started.
