Author Topic: fmic pipework help  (Read 6965 times)
Offline golfyste
  • Project track car
Re: fmic pipework help
« Reply #10 on: 24 September 2012, 07:58 »
You people really need to star looking in the maintenance and Info section as there ate a lot of useful stickies  :laugh:
http://www.golfgtiforum.co.uk/index.php?topic=238012.0
Offline rio_gti
« Reply #11 on: 24 September 2012, 10:43 »
map sensor pipe???  :undecided:
Offline Prawny
  • R-tech power!!!
« Reply #12 on: 24 September 2012, 10:58 »
Copied from Dundeals post......................
nope all you need is this
Intercooler specs are 600 x 300 x 76mm http://www.ebay.co.uk/itm/FMIC-FFRONT-MOUNT-TURBO-INTERCOOLER-TYPE-B-600x300x76MM-/310228624694?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483b112536#ht_674wt_1163
2 x 90 degree 76mm hard pipes with beaded ends. http://www.ebay.co.uk/itm/90-Degree-Alloy-Aluminium-Pipe-Bend-Elbow-Intercooler-Pipework-Air-Intake-/160658691823?pt=LH_DefaultDomain_3&var=&hash=item25680116ef#ht_1832wt_1163
2 x 90 degree 76mm silicone elbows in your choice of colour - these will need adjusting to length during fitting. http://www.ebay.co.uk/itm/90-Degree-Silicone-Elbow-Bend-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Car-/330650756290?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item4cfc5224c2#ht_1102wt_905
2 x 90 degree 76 - 63mm reducing silicone elbows in your choice of colour. http://www.ebay.co.uk/itm/90-Degree-Reducers-Silicone-Elbow-Bend-Hose-Silicone-Rubber-Coolant-Rad-Pipe-/270865046133?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3f10d09a75#ht_1102wt_905
2 x 63mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
2 x 76mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
1 x 76mm 250mm length of straight silicone hose in your choice of colour. This needs to be cut into 2 lengths of 125mm to go on the end tanks of the cooler. http://www.ebay.co.uk/itm/1-Meter-Straight-Silicone-Hose-Size-Colour-Choice-Roose-Motorsport-/251051638993?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3a73d800d1#ht_2300wt_1163
10 x 70 - 90mm jubilee clips http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
2 x 50 - 70mm jubilee clips. http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
hi there can some one tell me if this is rite or not thanks
Without knowing how he plans to lay it all out, nobody knows!
I'd start by saying I think 76mm hard pipes and bends are a bad idea though, best to reduce straight down to 63 with 76-63 90 degree silicon reducers off the core.
I wrote quite about it in the thread that's linked above:
Offline rio_gti
Offline Prawny
  • R-tech power!!!
« Reply #14 on: 25 September 2012, 06:44 »
because that costs you £310, and a better setup can be built for about £200 :), or £230ish for an AUM
Offline rio_gti
« Reply #15 on: 25 September 2012, 10:06 »
it can??  :huh:
gonna start looking back into this soon  :whistle:
Offline Chris#101
« Reply #16 on: 25 September 2012, 18:09 »
Regards to your write up
Am I right in thinking this is how you set yours up (I know yours changes slightly down nearer the cooler but this will be for my golf) ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline rio_gti
« Reply #17 on: 25 September 2012, 19:25 »
Where did you get those rims from????  :laugh:
Lovin that sketch thou makes it well clear  :wink:
Offline Prawny
  • R-tech power!!!
« Reply #18 on: 25 September 2012, 21:49 »
That's fantastic Chris, and exactly how mine is 100% :)
Nice drawing skills!
Offline Chris#101
« Reply #19 on: 26 September 2012, 12:33 »
Brilliant thanks for clearing that up  :cool: Ive got 2.5" from the cold side to t.b but hot side to turbo is a measley 1.75"  :sick:
Also I dont suppose you can remember the leg lenths you ordered can you? as theres dufferent lengths available?
cheers  :smiley:
