Author Topic: fmic pipework help  (Read 6964 times)
Offline azzsmith
fmic pipework help
« on: 03 August 2012, 21:35 »
Hi all,
I have just bought a toyosports intercooler with 3" inlet and outlets.  :cool:  It comes with no pipework and tbh I have no idea of what angles, diameters etc etc to buy.
Only had the car a couple of months so not that clued up about it all yet!
Any help would be appreciated and possible some pics and pipework shopping list!
Cheers, azz  :smiley:
black magic agu 240bhp
Offline mar_k
Re: fmic pipework help
« Reply #1 on: 03 August 2012, 21:38 »
Copied from Dundeals post......................
nope all you need is this
Intercooler specs are 600 x 300 x 76mm http://www.ebay.co.uk/itm/FMIC-FFRONT-MOUNT-TURBO-INTERCOOLER-TYPE-B-600x300x76MM-/310228624694?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item483b112536#ht_674wt_1163
2 x 90 degree 76mm hard pipes with beaded ends. http://www.ebay.co.uk/itm/90-Degree-Alloy-Aluminium-Pipe-Bend-Elbow-Intercooler-Pipework-Air-Intake-/160658691823?pt=LH_DefaultDomain_3&var=&hash=item25680116ef#ht_1832wt_1163
2 x 90 degree 76mm silicone elbows in your choice of colour - these will need adjusting to length during fitting. http://www.ebay.co.uk/itm/90-Degree-Silicone-Elbow-Bend-Hose-Silicon-Rubber-Coolant-Radiator-Pipe-Car-/330650756290?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item4cfc5224c2#ht_1102wt_905
2 x 90 degree 76 - 63mm reducing silicone elbows in your choice of colour. http://www.ebay.co.uk/itm/90-Degree-Reducers-Silicone-Elbow-Bend-Hose-Silicone-Rubber-Coolant-Rad-Pipe-/270865046133?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3f10d09a75#ht_1102wt_905
2 x 63mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
2 x 76mm alloy joiners. http://www.ebay.co.uk/itm/Metal-Alloy-Aluminium-Hose-Joiners-Pipe-Connectors-Silicone-Rubber-Select-Size-/270867577918?pt=LH_DefaultDomain_3&var=&hash=item3f10f73c3e#ht_1126wt_905
1 x 76mm 250mm length of straight silicone hose in your choice of colour. This needs to be cut into 2 lengths of 125mm to go on the end tanks of the cooler. http://www.ebay.co.uk/itm/1-Meter-Straight-Silicone-Hose-Size-Colour-Choice-Roose-Motorsport-/251051638993?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item3a73d800d1#ht_2300wt_1163
10 x 70 - 90mm jubilee clips http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
2 x 50 - 70mm jubilee clips. http://www.ebay.co.uk/itm/W4-Stainless-Steel-Zinc-Plated-Worm-Drive-Hose-Clips-Mikalor-ASH-Jubilee-/270925388819?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3f14695c13#ht_1102wt_905
Offline azzsmith
« Reply #2 on: 03 August 2012, 21:40 »
Ok thanks mate.
Do you know whether this is all thats needed or is there anything else?  :huh:
Offline mar_k
« Reply #3 on: 03 August 2012, 21:45 »
Not sure as I havent done it myself,
Offline cullygti
« Reply #4 on: 03 August 2012, 21:46 »
that is a big cooler  :cool:
Offline azzsmith
« Reply #5 on: 03 August 2012, 21:47 »
Ok, thanks for you'r help mar_k  :smiley:
Offline azzsmith
« Reply #6 on: 03 August 2012, 21:49 »
I'll take that as a compliment  :laugh: lol
Offline azzsmith
« Reply #7 on: 03 August 2012, 22:34 »
Also if anyone has any guides with pics would be appreciated  :tongue:
Offline ReDBull
« Reply #8 on: 03 August 2012, 23:20 »
Have you looked at the other FMIC thread there's lots of info on the welleycooler there.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline markgti1.8t
« Reply #9 on: 23 September 2012, 21:42 »
hi there can some one tell me if this is rite or not thanks
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
