Author Topic: Dropped the car off at R-Tech  (Read 1704 times)
Offline Scott D
« on: 28 July 2012, 20:59 »
Drove down to Hinckley dropping the car of at R-Tech this time with a slightly different turbo, ported manifold and FMIC. Had a stage II map for over 18 months that has been faultless, pulled very well and surprised a few cars in that time  - which is why I didn't consider taking the car anywhere else.
Spec is:
Borg Warner K04-001
Forge Actuator - Yellow Spring
Milltek 3" Sports Cat DP & 2.5" Non-res cat back
Sachs Clutch & Single Mass Lightweight Flywheel
BAM 3" MAF, Pump & Injectors
Ported Manifold
Forge FMIC
Jetex Induction Cone
Creations TIP & Boost Hoses
PCV delete
Not looking forward to driving the missus's 1.0 3cyl corsa next week and even more nagging about spending far too much money on a sh!tty old golf  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Toby
  • Car - less
Re: Dropped the car off at R-Tech
« Reply #1 on: 28 July 2012, 21:05 »
Lmfao!
Ur story was the same as mine, r tech, big turbo, 1l corsa and mrs moaning!!
A men!!
Currently down under
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 July 2012, 21:10 »
awesome mate, hope you didn't forget the hobnobs  :wink:
Offline golfyste
  • Project track car
« Reply #3 on: 28 July 2012, 22:09 »
Hmmm sounds familiar ;)
Looking forward to seein the results  :wink:
Sure you will be happy
What power were you currently running?
Offline Scott D
« Reply #4 on: 01 August 2012, 19:49 »
will take a few packets down on the return trip  :wink:
it was running around 230 & 250ft-lb before.
Offline Scott D
« Reply #5 on: 04 August 2012, 21:58 »
Back from R-Tech after a steady drive home with a lot less turbo lag and slightly more torque.
They've done an awesome job and huge credit to them for getting the car ready today. I honestly can't recommend them enough, spot on customer service and can't believe how much better the car is driving, that said am considering trading in the golf for a 1.2 Clio with NOS  :grin:
It was running around 230bhp & 250 ft-lb before and now has 244bhp & 297ft-lb. Not a huge difference in power and I was hoping for closer to 260 but the sports cat wasn't helping flow at all, that said after going for the test drive changing the k03s just about became justifiable - spool up is immense no matter what gear there's hardly any lag and that increase in torque has made a huge difference, pulls seriously well on the motorway even in 6th gear and holds 22/23psi, all about that mid range torque!
De-cat will be going on before the end of this month. Timing belt is due in March next year so considering getting the rods done, actuator spring changed to blue as advised and WMI kit around then - well impressed by that k03s on meth, 266bhp and had done 180k+ miles.. proper quick!
And a bonus was the trip computer MPG on the way back, not really arsed about fuel economy but rarely ever went beyond 35mpg before so well worth a picture, put almost a full tanks worth in after leaving and its still above half full.
Huge thanks to you all!
Offline JimBR
« Reply #6 on: 04 August 2012, 22:08 »
Bet thats awesome to drive! Huge area under those curves.
Offline tokemk4gti.t
  • 2001 gti turbo :-)
« Reply #7 on: 05 August 2012, 10:06 »
how much corn didn this little lot cost mate?
