Author Topic: Power Steering Pipes  (Read 4324 times)
Offline WadGTI
  • Golf GTI'er
« on: 21 July 2012, 14:48 »
Hi Folks,
Any one know the going price for a set of power steering pipes from Volkswagon? Had a few checks with a few parts traders but they dont have any supply.
Just relised my golf is due its mot in 2 weeks. Got the fuel tank to change over too.
I can probs get a set of pipes from a vr6 but not sure if they fit the 8v.
Does corrosion on the pipes fail now? Anyone know if they pipes come as 2 parts as I know they did with mk3 polo.
Many thanks
Offline andy-gti84
  • lowanslow
Re: Power Steering Pipes
« Reply #1 on: 21 July 2012, 15:28 »
dont no price but if it just to get it pas a mot then just wire brush them all an use wd40 then greas or copper seal them. iv done this loads of time with brake line etc an all ways have passed  :grin: then just change then when iv had time.
VW BUSH
« Reply #2 on: 21 July 2012, 16:00 »
They aint cheap about 60 quid a hit when I looked....
Unless they are really minging or leaking, just wire brush them and  waxoil  :wink:
Offline filthy
« Reply #3 on: 21 July 2012, 18:47 »
I can make them, give me a call on 07917 697262.... Not on here much.....:smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #4 on: 21 July 2012, 19:19 »
Mine were horrendously rusty but after removing them and hitting them with a grinding stone on the end of an air tool and a lick of hammerite they look like new. Takes alot of rust for them to break or leak fluid. There is actually 3 pipes, the two large main ones and a short one that runs across the front crossmember.
Offline WadGTI
  • Golf GTI'er
« Reply #5 on: 23 July 2012, 12:41 »
Thanks guys, I cans ee the front section pipe has some corrosion on it (not leaking ) - I think as I don't have an undertray the water has done its damage. I will try and wirebrush off and grease it up. I will have a look at the other 2 sections to see how bad they are.
I changed the power steering pipes on my old polo 2 - 3 years back and the pipes came in to sections and VW charged me £250 for it :sad:
Sorry this questions is a bit off topic - I am going to change my petrol tank on Friday  - Anyone know if it is a big pain to do it. I will have someone to give me hand.
Thanks guys...much appricated.
Liam
Offline Len
« Reply #6 on: 23 July 2012, 12:43 »
Petrol tank is a pain and yes you will need a hand.
Worst bit I found was getting the neck to come out and down as its attached to the tank.
www.sas.org.uk
www.the-ace.org.uk
Offline Gti_Jamo
« Reply #7 on: 23 July 2012, 18:08 »
Tanks not too bad to do. Remove the round panel under the boot carpet and remove the hoses and connector from the fuel pump, then there is a bolt up at the top holding the filler neck in position and then you have all the bolts that hold the straps on then it should drop out. Some good ground clearance is essential. Its not too heavy if its more or less empty as its plastic.
Offline WadGTI
  • Golf GTI'er
« Reply #8 on: 25 July 2012, 12:23 »
Thanks guysd, this should help  - this is what happens when the previous owners don't clear the drain hole on the filler neck!
One more question - any one knopw if the mk3 vr6 and gti tanks are the same?
Thanks
Offline madmanmart
« Reply #9 on: 25 July 2012, 12:59 »
Thanks
Yes they are
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
