Author Topic: SORTED!! whine noise from induction?  (Read 12686 times)
Offline Giro
Re: HELP whine noise from induction?
« Reply #20 on: 25 July 2012, 18:59 »
How much  :sick:
feck me, should have posted in the wanted loads of people dont run them now with catch cans installed.
Anyone have a puck for this guy .........
gutted never gave it a thought just rushed out to try and fix it asap
and the part doesn't solve the problem  :cry:
tryed the new puck and i can blow both ways so i fitted it and its made no difference
if i take the boost controler plug off the noise is quieter but theres no boost
so its boost related
few mechanics have checked the car and they are puzzled they gess to fit a new turbo but im not convinced  :undecided: :sick:
anyone help?
« Last Edit: 25 July 2012, 19:03 by Giro »
Offline Giro
« Reply #21 on: 25 July 2012, 21:53 »
cars a way for a smoke test tomorrow
ill keep you in formed with the news
might get a manual water boost gauge fitted to check how its boosting  :sad:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #22 on: 25 July 2012, 22:34 »
get the TIP off at the turbo end and see if you can wiggle the shaft about at all
Offline Giro
« Reply #23 on: 26 July 2012, 18:35 »
im not sure how to get it off?
ive had the car for a smoke test today and no leaks
time for a new turbo :(
i was told today that the AUQ engine has a ko3s turbo is this right?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #24 on: 26 July 2012, 18:59 »
you just need to pop it off where it joins to the inlet on the turbo, best done from under the car. My guess from the noise is worn bearings which will mean your compressor wheel will move in/out and side to side. The noise is generated as it is out of balance
Yes the AUQ has a K03s
Offline Giro
« Reply #25 on: 26 July 2012, 21:54 »
could i get it repaired/serviced ?
or buy a recon??
Offline pickles
  • Next!!!
« Reply #26 on: 27 July 2012, 09:21 »
upgrade time  :laugh: upgrade time :) £££
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Giro
« Reply #27 on: 27 July 2012, 18:40 »
ha i would if i was minted  :rolleyes:
i might have about £300 to spend if im lucky
Offline jamie1989
« Reply #28 on: 27 July 2012, 18:48 »
Thats plenty mate,
Mine made this noise when I fitted the k03s to my AGU, Turned out the pancake pipe weren connected tidy and blew the pipe off lol Quick fix for though.
It could be soo many diff things, Just take the turbo intake pipe off and check the shaft yourself its a 5min job literally.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Giro
« Reply #29 on: 28 July 2012, 09:09 »
Thats plenty mate,
i will try this and get back to you
whats the pancake pipe?
