sounds like something is split and sucking air in somewhere to me, check everything!
Both sides of the DV, the vac pipe on top of the dv (make sure you are using 4mm ID tubing) and its tight (also what have you split the vac pipe off to takeoff to the DV)
very odd for it to still be there after changing the DV as it rules it being knackered out
