Author Topic: SORTED!! whine noise from induction?  (Read 12705 times)
Offline pickles
  • Next!!!
Re: HELP whine noise from induction?
« Reply #30 on: 28 July 2012, 10:15 »
Thats plenty mate,
Mine made this noise when I fitted the k03s to my AGU, Turned out the pancake pipe weren connected tidy and blew the pipe off lol Quick fix for though.
It could be soo many diff things, Just take the turbo intake pipe off and check the shaft yourself its a 5min job literally.
i will try this and get back to you
whats the pancake pipe?
https://encrypted-tbn1.google.com/images?q=tbn:ANd9GcTFLxrVbisuWKXhc9etbTbF5pQ9xY5rMfpmi-gqx-h81rm6DQPb
its down on the drivers side of the engine m8 on the inside of the wheel kinda, just follow the piping from the throttle body throught the intercooler and ul see it.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Giro
« Reply #31 on: 28 July 2012, 16:35 »
update.........
:cry: 1 bent fin
no play and spins nice, cant see any marks on the blades or the housing
ordering new k03s turbo tonight
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #32 on: 28 July 2012, 17:47 »
not tried bending it back?
Looks like something has dropped in there IMO
« Last Edit: 28 July 2012, 17:48 by Wazzzer »
Offline Giro
« Reply #33 on: 28 July 2012, 18:49 »
aye the thought crossed my mind, even had the thin nose pliers in my hands but all my m8s were shaken their heads! :laugh:
im thinking maybe crankcase pipe carbon deposit has shot through to the induction and hit the blades
or my aftermarket filter has drawn a little moist water? time to give the engine an oil flush and original filter ansd housing back on i think  :embarassed:
Offline Dalo Harkin
« Reply #34 on: 28 July 2012, 19:32 »
Definately foreign object damage, or someone has done it when fitting a TIP at some point  I would try bending it back as Wazzer has said, especially if nothing else wrong with it, or just replace the wheel rather than the whole turbo especially as you dont normally know the history about other second hand turbo's.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #35 on: 28 July 2012, 20:39 »
What you got to lose  :wink:
Offline Giro
« Reply #36 on: 28 July 2012, 21:01 »
nowt lol but its a highly balanced unit so even if i did get it stright it might be a little bit out of balance and end up damaging the seals and bearings
could i just take the nut off slide the compressor wheel off and replace it with just the tip off???
surely some one will have an old k03s unit with bad bearings and a good compressor wheel lying about or will this not work?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #37 on: 28 July 2012, 21:12 »
you've just contradicted your argument :wink:
if you did manage to get another wheel it won't be balanced to the exhaust wheel so you'd be in the same position. I would bend it straight as poss and see how you go, can't be any worse than it is now
Offline Giro
« Reply #38 on: 28 July 2012, 21:18 »
 :embarassed: dohh didn't think of that
but wont that weaken the blade and may snap off and go through the engine?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #39 on: 28 July 2012, 21:22 »
should be ok if you do it gently with a bit of heat
