Author Topic: Brake fluid  (Read 1758 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Brake fluid
« on: 18 July 2012, 13:43 »
After getting my car back from the stealers yesterday, for coilpack recall. they also left me a list of things that needed doing. One of the important things was brake fluid, so what is the best brake fluid for me to get, as I am having it done on monday
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Brake fluid
« Reply #1 on: 18 July 2012, 14:00 »
Dot 4. Just get some 'branded' dot 4 and that should be fine.
Re: Brake fluid
« Reply #2 on: 18 July 2012, 14:03 »
Thanks  :smiley:
Will this do the job http://www.ebay.co.uk/itm/270994022820?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline Dalo Harkin
Re: Brake fluid
« Reply #3 on: 18 July 2012, 14:03 »
Thanks
Why would they have been messing with the brakes to know it needed fluid  :shocked:
Re: Brake fluid
« Reply #4 on: 18 July 2012, 14:06 »
Thanks
They did something called EVC (Express Visual Check) they also said i needed other things, totalling about £1000  :shocked:
Offline scarr89
Re: Brake fluid
« Reply #5 on: 18 July 2012, 14:08 »
Thanks  :smiley:
I wouldn't to suggest any particular stuff to you just in case it is not suitable. However, brake fluid is brake fluid & ATE make the front callipers on your car so I guess it would be ok. Get on eurocarparts, they have 31% off at the moment!  :smiley:
Re: Brake fluid
« Reply #6 on: 18 July 2012, 14:28 »
Thanks  :smiley:
Thanks for the tip   :smiley:
Offline JimBR
Re: Brake fluid
« Reply #7 on: 18 July 2012, 17:45 »
VW do it for about £60 I think and will pressure bleed it properly. I'd let them do it. Brakes on clutches are a nightmare to bleed on these I've found lol.
Re: Brake fluid
« Reply #8 on: 18 July 2012, 19:22 »
VW quoted me £71.40  :shocked:
It is not something I would even attempt to do myself. I use a VAG expert who used to work at the local VW place some time ago, but he left and set up his own garage. He does all the work on my car that I can't do, and he is really very good, and more than reasonable on price  :smiley:
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Brake fluid
« Reply #9 on: 19 July 2012, 01:51 »
Brake fluid change £59, when I went couple of weeks ago they offered deal on full aircon service if I had that done with brake fluid change total would be £99 :) full aircon service is normally £79
That was at VW Shrewsbury
