Author Topic: Brake fluid  (Read 1766 times)
Offline JimBR
Re: Brake fluid
« Reply #10 on: 19 July 2012, 07:18 »
By the time you've been to TPS got the brake fluid and a proper pressure bleed kit the cost wont be much different. I'd much rather let them do it, it's probably the only job I'd take my car to VW for.
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: Brake fluid
« Reply #11 on: 19 July 2012, 09:22 »
The brake fluid cost me £16, I am not buying the pressure bleed stuff, as I am not doing it, my usual VAG mechanic is! I will post here to tell how much he charges me for it.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline theshrew
Re: Brake fluid
« Reply #12 on: 19 July 2012, 16:46 »
just take it to a local garage not the dealers you will save ££££
Bleeding brakes is a simple and easy job ( if it goes to plan ) nothing special about it that requires a dealer
