Author Topic: VAGCOM Coding.........Pretty Please........!!  (Read 3245 times)
Offline RedHP
« on: 16 July 2012, 19:23 »
Hey boys and girls,
I'm sure that this has been covered before but there are just too many results after using the search function. I realise that I am being lazy but I am now on borrowed time and need to get the issue resolved asap, hence my post.
I had a retrofitted LED with DRL's headlamp set fitted on my GiT 2010, which were purchased from China, but I can't get the correct coding for all lights to work as they should.
1. The DRL's work when in-car light setting on 0 and Auto only, not when on sidelights or even when main beams come on (either via Auto or 'On')
2. When light setting is switched to 'Sidelights', no lights at all come on up front
Can anyone please confirm the correct coding to get the new headlamps to work as they should pretty please.....?
PS Kenneth (KennyGTI), many many thanks for your help so far - you are a diamond geezer    :smiley:
Red
Mk6 GiT since birth in 2010
YNWA
Offline AndyG
Re: VAGCOM Coding.........Pretty Please........!!
« Reply #1 on: 16 July 2012, 20:20 »
Regarding the LED DRL's,could you not simply take a 12v feed straight from the battery via a fuse and give them a switched feed,leaving your main beam switched as it was before.The DRL'S would then be on all of the time as they should be.If I'm talking nonsense sorry,just a suggestion.
« Last Edit: 16 July 2012, 22:23 by AndyG »
Golf 7R,DSG,5 door White,leather,rear camera.
Offline Buck
  • Das Auto
« Reply #2 on: 16 July 2012, 21:57 »
Red
I know it's a long shot but is there any other forums where a user has bought these and installed?
Were there any instructions that came with the lights that we might be able to help decipher?
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #3 on: 17 July 2012, 02:57 »
Where are you located?
Offline KennyGTI
« Reply #4 on: 17 July 2012, 11:58 »
No worries matey.
"2. When light setting is switched to 'Sidelights', no lights at all come on up front"
Thats same as me mate, sidelight selected = no lights on at all. The LEDs became my DRLs, and there is no other bulbs to become your sidelights so nothing will come on.
I'll have another look through other forums. I cannot understand why my code did not work with yours?
APR Stage 2+
Offline KennyGTI
« Reply #5 on: 17 July 2012, 12:35 »
Have look through this. Seems your not the only one. I am sure you will get it eventually, just a matter of messing about.
http://www.golfmk6.com/forums/showthread.php?t=33377
And another:
Here's a link with some coding instructions at the bottom of the page and I believe that he's using the euroswitch. His is a 2012 and it appears that he didn't have to touch byte 18.
http://www.golfmk6.com/forums/showth...=30007&page=13
He used:
Byte 9 bit 3, 7
Byte 11 bit 7
Byte 12 bit 5, 6
Byte 14 bit 0, 3
Byte 15 bit 2
Byte 17 bit 0
Byte 24 100
Byte 26 (nothing)
Byte 27 bit 2, 5
Good luck.
APR Stage 2+
Offline RedHP
« Reply #6 on: 18 July 2012, 15:58 »
In the Northants area Doc
YNWA
Offline RedHP
« Reply #7 on: 18 July 2012, 16:01 »
Kenneth - Ah now I understand why the 'sidelights' don't work !
Ok, but any idea's as to why the DRL's do not work when main headlights are on ??
Thanks, I'll give these bits a go !
Thanks all
Red
YNWA
Offline KennyGTI
« Reply #8 on: 18 July 2012, 21:38 »
I cannot help you out there mate. It's a weird one but did read on the other forums that people were having similar issues. Just need to look through the different forums and get to the bottom of it.
APR Stage 2+
Offline SteveP
« Reply #9 on: 18 July 2012, 21:47 »
Im in South Northants if you need some coding help  :smiley:
