Author Topic: VAGCOM Coding.........Pretty Please........!!  (Read 3243 times)
Offline KennyGTI
Re: VAGCOM Coding.........Pretty Please........!!
« Reply #10 on: 19 July 2012, 07:12 »
^^^^^^^^ the very man that will be able to help you!
APR Stage 2+
Offline RedHP
« Reply #11 on: 20 July 2012, 15:12 »
Im in South Northants if you need some coding help  :smiley:
PM'd
Mk6 GiT since birth in 2010
YNWA
Offline mickjane2
« Reply #12 on: 06 October 2012, 17:02 »
I have a 2012 Golf Gt DSG which I have fitted an RNS 315 DAB unit (mid 2011), I had a guy with Vag/Com come round and enabled the MFD and the PTT button on the steering wheel, my problem is I still don't have voice control. The internal B/T unit was turned of so that I still have the 9W7 B/T unit under the drivers seat as I was told that I would have a micro phone problem if I kept the 315 internal B/T unit, any help would be much appreciated. Mick
Offline Jimble
« Reply #13 on: 06 October 2012, 17:47 »
I don't think the RNS 310 supports voice control mate so the BT module has to be wired up differently, something to do with joining the mic cable, i had the same issue with my RCD510 but my BT was fitted by a fellow forum member so i'm not sure exactly how to do it :sad: i'm sure someone will be along shortly who can help you out. :wink:
