Author Topic: No boost leaks but not 1oo% power  (Read 3101 times)
Offline pickles
  • Next!!!
Re: No boost leaks but not 1oo% power
« Reply #10 on: 03 July 2012, 23:02 »
can you not just delete you N249 and the other valve with the guides on here, less too worry about i suppose
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #11 on: 03 July 2012, 23:06 »
I am not too sure about deleting it, surely it has a purpose  :undecided:
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #12 on: 03 July 2012, 23:09 »
Do the full N249 bypass  :wink:
 01455 617233
« Reply #13 on: 03 July 2012, 23:13 »
If I do that do I have to delete or by pass anything else ?
Offline rio_gti
« Reply #14 on: 03 July 2012, 23:15 »
Just bypass it!!! Check maintenance section for the how to
« Reply #15 on: 03 July 2012, 23:20 »
OK chaps! Thanks, I will attempt this tomorrow...hopefully  :cool:
« Reply #16 on: 04 July 2012, 00:45 »
Just read Bav's guide to doing the N249 bypass, and looks fairly simple enough to do. If this doesn't work then I think I may just give up and save my money up from now on, and put it towards buying another more powerful but unmapped car!
Offline Dalo Harkin
« Reply #17 on: 04 July 2012, 07:10 »
It should be done anyway really if nothing else its one less thing to go wrong, I used this guide here:-
http://forums.vwvortex.com/showthread.php?3111538
« Reply #18 on: 04 July 2012, 07:40 »
Thanks mate  :smiley: I see in that link he shows how to remove the SAI, while Bav's he doesn't recommend that is done, as he put his back on after taking it off. Plus I have had the rivets in the pump changed to bolts, as recommended by Nick at R-tech when he remapped my car. As that apparently stops the thing from leaking.
Offline Dalo Harkin
« Reply #19 on: 04 July 2012, 07:53 »
Yes it does stop it leaking if you do the bolt mod, I removed the SAI because the ribbed pipe that connects to it cracked and VW wanted something like £16 a section x 2 or 3 sections  :shocked:
I also use a CAI so didnt need to run the pipe into the Airbox
frees up loads of space in the bay, when I get round to it I'll do some pics  :nerd:
Bavs replaces all the standard tubing which is prone to breaking down and splitting with silicone tubing where as the link I posted removes the N249 and N112 and the hardlines are replaced with 2 sections of silicone tubing, one from the plenum to the DV and one from the plenum to the FPR
In short if it can go, on mine it goes  :grin:
