Author Topic: No boost leaks but not 1oo% power  (Read 3117 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 03 July 2012, 15:03 »
OK, I have eliminated all boost leaks, with a catch can and the usual silicone hoses, tip, charge pipe, 5 piece turbo boost hose kit ect ect. Plus I had a smoke test yesterday which suggested the dipstick, which I have now sealed up. I have a forge 007 dv, new N75 and new maf, ( both 5 months old) new coolant temp sensor. My boost gauge sits at 20-22 on idle.
I can feel that that it boosts but holds back in 2nd and 3rd. At a guess it is probably about 175-180 bhp, running a stage one r-tech remap, and as it is an Aum should be about 200+ bhp.
What should I check next? I have free version of vag com, but there are no fault codes showing!
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Rhyso
Re: No boost leaks but not 1oo% power
« Reply #1 on: 03 July 2012, 15:05 »
Not 100% sure what you can log with the basic VAGCOM but try and log your boost / MAF values
Think the MAF is block 2/3
Boost is 110 / 115
If you can log your MAF you can do a crude calculation to work out your approx bhp
« Reply #2 on: 03 July 2012, 15:09 »
Boost is 110 / 115
Thanks!
I think I can only log up to blocks 25, so I should be able to do the maf readings. So am I right in thinking I log blocks 2 & 3 or are saying it is 2 or 3.
Do I need to rev it and keep it at a certain rev, or do I need to drive it while doing it (with someone else of course logging it)
« Reply #3 on: 03 July 2012, 15:25 »
Just found a file download with "instructions for logging with vagcom"  :smiley:
Offline Rhyso
« Reply #4 on: 03 July 2012, 15:27 »
It is either Block 2 or 3  :smiley:
Full throttle run from 1500rpm to the red line in 3rd
What you should see from the MAF readings is a nice steady increase towards the peak BHP; take the highest figure and divide by 0.8 to give you a rough idea  :smiley:
If you have fluctuations in your MAF then its either your MAF or something, somewhere is causing it to read low
« Reply #5 on: 03 July 2012, 15:31 »
Wonderful stuff! Nice one  :smiley:
Offline Dalo Harkin
« Reply #6 on: 03 July 2012, 15:55 »
In terms of being low on power, could be loads of things, actuator being one of them, MAF as you have said, exhaust system etc etc
Offline daz veedub
  • Operation 1.8t bolf
« Reply #7 on: 03 July 2012, 15:59 »
ignition amp  :undecided:
« Reply #8 on: 03 July 2012, 16:23 »
I hope it isn't the maf, as I only bought a new one from TPS about 3-5 months ago. I will get the logging done this week when i can get someone to help me with it, and when it is a bit dryer  :wink:
I just googled this , and apparently if it is this then it will miss fire badly. Is that correct? Mine does not miss fire at all, well not that I have noticed.
« Reply #9 on: 03 July 2012, 22:59 »
OK, an update. After taking the car for a spin earlier, the boost only holds at 9psi  :huh: So I plugged in my hand held code reader (as I didn't have my vagcom or laptop with me) and I get a code  :angry: 17608. So after googling it I see it is either the diverter valve, or the N249 valve. So i guess it can't be the DV because that is a Forge 007 which is only about a year or so old. So it must be the N249 valve.
It seems to be one thing after the next with these cars!!! I get one thing fixed and then it finds the next weakest thing to go. arghhhhhhhhh :angry:
How much is an N249 going to set me back, and do I just get a normal vw one from TPS or dealers, or is there a better after market one?
