Author Topic: smoke test just done!  (Read 11241 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 02 July 2012, 18:21 »
I found a garage that does smoke tests, it cost me £25 which I thought was reasonable, and the leak it found was coming out of the top of the dipstick! As soon as the mechanic took the dipstick out and plugged the hole with his thumb there was no smoke.
So as I have a oem plastic dipstick holder and dipstick, what is best to replace it with? I have seen some metal ones on some cars with nice shiny silver handles. Any idea where I can get one of those metal ones from?
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Scott D
Re: smoke test just done!
« Reply #1 on: 02 July 2012, 18:33 »
think they maybe by 42 draft designs in the states, very expensive IIRC.
on the plus side least its an easy fix and no other leaks found :)
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Chris.
« Reply #2 on: 02 July 2012, 18:50 »
Dont you block the PCV system up on the TIP?
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 02 July 2012, 19:22 »
yeah or you pressurise the sump...
I always hook mine up to start from the metal pipe after the turbo
« Reply #4 on: 02 July 2012, 19:35 »
I had a look on 42 Draft design site, and I can't see any.
At first he thought it was coming from the inter cooler because the smoke seemed to be coming up from the radiator, but after it was the top of the dipstick, it does fit in although it is not a super tight fit. Would this cause a significant boost leak then?
Yes he did do that with a yellow plastic cap of some sort.
Offline GunnerCP
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 02 July 2012, 19:40 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 02 July 2012, 19:43 »
£54  :shocked:
LMAO @ "medium whack", my mallet doesn't have that setting  :grin: :grin: :grin:
Offline wasps1990
  • Per Mare, Per Terram
« Reply #8 on: 02 July 2012, 19:46 »
http://www.awesome-gti.co.uk/product.php?xProd=29687&xSec=9919
Bargain.....
i love the fitting instructions :grin: whack it with a mallet
i bought one 3 months back n i have been chasing up awesome every week since
Offline GunnerCP
« Reply #9 on: 02 July 2012, 19:49 »
Yea, not quite sure how you quantify what a medium whack is. Then you have to repeat the process, so.... To summarise.....
Bash the sh!t out of it until it fits but only use a medium whack during any one strike.....
