Author Topic: smoke test just done!  (Read 11182 times)
Offline Scott D
Re: smoke test just done!
« Reply #20 on: 02 July 2012, 20:52 »
they are fragile both the pipe and dipstick after years of use, I remember swapping both parts over and the top plastic connecting part of the dipstick crumbled in my hand after removing.
if replacing them go direct to VW for proper parts and avoid ebay - buy cheap buy twice
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #21 on: 03 July 2012, 07:38 »
Thanks, I will then. The tube is only about a year old, but the actual dipstick is the original one, so I think I will take a trip to my local dealers tomorrow and buy both tube and stick.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Dalo Harkin
« Reply #22 on: 03 July 2012, 07:40 »
Just be careful taking the tube off, mine crumbled everywhere
« Reply #23 on: 03 July 2012, 07:52 »
thanks, but luckily mine is ok at the moment, as I took it off the other day when I installed my catch can, and it is fine
Offline cobalt6700
« Reply #24 on: 03 July 2012, 17:59 »
Err, you shouldnt have any smoke coming from your dipstick?  :huh:
The only way the smoke can get in the sump is past the rings....
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline Dalo Harkin
« Reply #25 on: 03 July 2012, 19:56 »
It was being smoke tested  :grin:
Offline cobalt6700
« Reply #26 on: 03 July 2012, 20:58 »
Yeah I get that :)
What am I missing? Can't see a path from intake to sump?
Offline Anthony
« Reply #27 on: 03 July 2012, 21:02 »
I was Thinking excactly the same thing
2003 GT Tdi 150
Offline rio_gti
« Reply #28 on: 03 July 2012, 21:40 »
Can I do a smoke test myself by taking puck out, blocking it, removing maf and pumping smoke into the tip??  :embarassed:
« Reply #29 on: 03 July 2012, 22:44 »
As far as I know he said he had to smoke test two ways, from two different locations in the engine bay, I just can't remember the locations. One for vacuum, and the other for brake, I think  :undecided: something like that. He put 15psi through it, and the smoke was coming up above the dipstick and around the gap in between the metal plate that fixes to the inlet manifold and radiator. He first thought it was the intercooler, (I have a side mount oem) we checked the plastic pipes, like the cold air feed and the other one in the location in front of the dipstick, but it wasn't these. After this he blocked off the top of the dipstick tube with his thumb, which seemed to stop as much smoke, and that was his diagnosis. The smoke is not always that easy to see though, as you need a bright light or a uv light to spot it.
