Author Topic: best turbo  (Read 1287 times)
Offline markgti1.8t
best turbo
« on: 24 June 2012, 18:50 »
hi there whats the best turbo for 300 bhp and acceleration for a 2000 reg golf
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline turbokid23
Re: best turbo
« Reply #1 on: 24 June 2012, 19:10 »
K04 off s3 or hybrid
Offline Chris#101
Re: best turbo
« Reply #2 on: 24 June 2012, 19:12 »
a fack awfff big Garret  :grin:.....
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Scott-R
  • GoT BoosT!
Re: best turbo
« Reply #3 on: 24 June 2012, 19:24 »
I got a ko4-001 i think its the same as a ko3-s, wee bit better and a lovely amount of boost and it boosts up quickly not much lag! :)
Golf GTI ... What else would you have?
Offline markgti1.8t
Re: best turbo
« Reply #4 on: 24 June 2012, 19:37 »
what else did you have to do when you where fiting the k04
Offline golfyste
  • Project track car
Re: best turbo
« Reply #5 on: 24 June 2012, 20:15 »
K04-001 is a good turbo but 300hp is a bit of a push better with a k04-023 or hybrid etc
Offline littco
Re: best turbo
« Reply #6 on: 24 June 2012, 20:59 »
Best turbo is hybrid k04. Stock k04 with mods will get you 300 but you'll have to nail the arse off it. Hybrid running sensible boost will give you a much better drive.
Re: best turbo
« Reply #7 on: 25 June 2012, 21:19 »
Going to need stronger engine internals as well.
Offline AaronGS
Re: best turbo
« Reply #8 on: 25 June 2012, 22:04 »
Get a ride in a Garret type turbo'd car, such as a GT28RS, and a ride in a hybrid turbo'd car and decide which you like best. One will make the power easier but one will have a bit less lag/accelerate a bit easier off the line. That will make it your decision, not everyone elses.
Where are you? I can give you a ride in a GT28 turbo'd car if you are nearby.
Offline markgti1.8t
Re: best turbo
« Reply #9 on: 25 June 2012, 23:14 »
Hi there I stay in Glasgow would be great if you could do that  :smiley:
