Author Topic: Bora vents  (Read 1537 times)
Offline m4rt1ngti
Bora vents
« on: 23 June 2012, 17:28 »
Considering doing this mod but im not 100% yet
If i was to purchase the loom to do it does that simply click into somewhere? What im saying is, is there any cutting of wires?
Is it a relatively simple thing to do?
Im happy to do most things but anything involving wires scares me
Offline Mr_Orange
Re: Bora vents
« Reply #1 on: 23 June 2012, 17:48 »
Make sure you get the illuminated ones (there are non-illuminated look same floating around).
No wire snipping necessary.  You can use a scotch lock into the headlight switch wiring and just ground it out to the chassis.
Build thread clicky
Offline m4rt1ngti
Re: Bora vents
« Reply #2 on: 23 June 2012, 18:05 »
Ok so what is a scotch lock?
Offline m4rt1ngti
Re: Bora vents
« Reply #3 on: 23 June 2012, 18:14 »
Or is it either scotch lock or the custom loom? Like i say electrics arent my thing :undecided:
Offline richw911
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bora vents
« Reply #5 on: 23 June 2012, 20:17 »
It's not too bad Rich, the plugs are nigh on £3 each now, repair wire £1.20. You're talking £12 for parts plus wire, a scotch lock and ring terminal, heatshrink, along with sleeve to make it look neat and I bet you'd be nearly there with the price
Offline richw911
Re: Bora vents
« Reply #6 on: 23 June 2012, 20:31 »
Ah ok :afro: - you are the forum bora vent wiring guru  :wink:  :laugh:
Offline m4rt1ngti
Re: Bora vents
« Reply #7 on: 23 June 2012, 21:27 »
Cheers for the help guys
"and attach the remaining two wires to any illumination source (Headlight switch etc for Power)"
Thats the phrase i dont like. So even when you buy the ready made loom you still have to chop some wires.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bora vents
« Reply #8 on: 23 June 2012, 21:30 »
A scotch lock will put a tiny nick in the wire casing in the cars loom allowing you to take a feed off it without cutting it. If you ever want to remove it you can and there will be hardly anything visable. It's just less intrusive than chopping and soldering wires
Rich - I'm useful sometimes  :laugh:
Running on empty now though, driving to Inters and back has done me in lol
Offline m4rt1ngti
Re: Bora vents
« Reply #9 on: 23 June 2012, 21:48 »
ahhhh i think im with you now.  :laugh:
When i get round to doing it i may annoy you again with more questions :nerd:
