Author Topic: lost key  (Read 8206 times)
Offline topher
  • Administrator
  • fully functioning
Re: lost key
« Reply #30 on: 25 June 2012, 21:27 »
then every mk4 i've done has had a dodgy door lock, which really wouldn't surprise me :grin: b5/b5.5 passats seem to suffer the worst with the door lock faults though for some reason
either way with a correctly cut key and an immo chip capable of being coded (unless its immo2) its a quick job if you already have the skc. if the alarm is going off while you're trying to do this you have issues somewhere other than the key
Offline old_n07
Re: lost key
« Reply #31 on: 25 June 2012, 21:53 »
You can't do that. Without the key being programmed, the immob won't let you in and the alarm will go off as soon as you try - that's what the 'chip' 'programmed key' is for, otherwise people would be stealing cars quite easily like in the old days.
Yes you can I've done it
How do you think I do cluster swaps, the keys aren't coded to the cluster when the ignition is switched on for the first time, all they need to do is turn the ignition on to get power to the cluster and then code them in to the cluster and the CCM.
Also the key "not being coded" has nothing to do with the alarm, all that is in the key is an immobiliser chip this doesn't have any effect on the alarm only the immobiliser
It does, the alarm will go off when a non coded key goes in and turns the barrel. I've coded keys also.
The car doesn't know if the key is coded as the immo chip has nothing to do with the alarm, you can turn the alarm off using a key blade in the ignition to switch the car on with no fob attached
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Ant1981
  • Feed me, prod me
Re: lost key
« Reply #32 on: 25 June 2012, 22:02 »
Yes it does.
Not a non coded one you can't, as that'll be what sets the alarm off as soon as you try in the barrel.
'09 Kawasaki Ninja ZX-6R
Offline topher
  • Administrator
  • fully functioning
Re: lost key
« Reply #33 on: 25 June 2012, 22:37 »
i feel a wager coming on :laugh:
Offline cullygti
Re: lost key
« Reply #34 on: 25 June 2012, 22:45 »
my non coded key that i had cut just to open the boot as it sometimes goes a bit dodgy does not set my alarm off but opens my doors and does not turn off my immobiliser
Offline topher
  • Administrator
  • fully functioning
Re: lost key
« Reply #35 on: 25 June 2012, 22:48 »
if there's an immo chip in the key you should've said so yesterday i had the gear to do that in jv's car :lipsrsealed:
Offline cullygti
Re: lost key
« Reply #36 on: 25 June 2012, 22:52 »
now you bloody say  :grin:
its ok mate i only had it cut purely to unlock the boot its a bog standard key not the flip type one as the boot kept destroying the flip type ones  :lipsrsealed:
