Author Topic: lost key  (Read 8205 times)
Offline Ant1981
  • Feed me, prod me
Re: lost key
« Reply #10 on: 24 June 2012, 18:25 »
generally around £250 including coding for other makes i have owned
But he'll need everything, he's lost the ONLY key.
I know. On a Vx you can get a cut key supplied and coded (by Vx) if there are no other keys. I think the key arrives at the dealers already cut - they get in to the car with it and can code the key from there... He would just need the AA to get his car to the dealers.
Or - what am I missing?
You need the ignition on to code the key, that proposed new key won't switch the ignition on as its not authorized/coded. The alarm will go off as soon as you try.
'09 Kawasaki Ninja ZX-6R
Offline DunnDeal12
  • Limited
Re: lost key
« Reply #11 on: 24 June 2012, 18:27 »
if you've lost you key you have to go into VW give them your V5 with VIN number and ID and they will give you a spanking new key fob from germany takes about 7 days to come costs £140 then £70 to get programmed to your car. i know it happened to me couple of months back i dropped my key in the canal lol.
forgot to include you have to get the car towed to the dealers to get the key coded in if you have AA/RAC/GreenFlag then your fine.
« Last Edit: 24 June 2012, 18:30 by DunnDeal12 »
Offline dan2252
Re: lost key
« Reply #12 on: 25 June 2012, 00:15 »
all you need to go is go dealers they should be able to order one. as people have said. it will need coding but it will unlock the car it just wont start it and the alarm will go off
MK4 golf 1.8 turbo agu :)
Offline old_n07
Re: lost key
« Reply #13 on: 25 June 2012, 08:53 »
You will need to get a new key from VW or some auto locksmiths can cut one by dismanteling the lock barrel, but as long as you can get the SKC you don't need to go to the dealers to get the key programmed anyone can do it with vagcom :afro:
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Bish922
Re: lost key
« Reply #14 on: 25 June 2012, 09:27 »
Remind me to never loose my spare key!  :laugh:
Offline dasan
Re: lost key
« Reply #15 on: 25 June 2012, 09:40 »
Check and see if you are covered by your Home Contents policy, i know i am covered for lost car keys
VW Golf GTI - 1.8T 2003 - Reflex Silver
Offline Ant1981
  • Feed me, prod me
Re: lost key
« Reply #16 on: 25 June 2012, 13:34 »
Only if the ignition is switched on.
Offline old_n07
Re: lost key
« Reply #17 on: 25 June 2012, 14:30 »
Which you can do without a key if you take the steering wheel surround off and remove the ignition switch from the barrell  :nerd: or use the new key blank you get cut at an auto locksmiths to power the car in, it doesn't matter about the immobiliser light being on.
« Last Edit: 25 June 2012, 14:37 by old_n07 »
Offline Ant1981
  • Feed me, prod me
Re: lost key
« Reply #18 on: 25 June 2012, 16:05 »
You can't do that. Without the key being programmed, the immob won't let you in and the alarm will go off as soon as you try - that's what the 'chip' 'programmed key' is for, otherwise people would be stealing cars quite easily like in the old days.
« Last Edit: 25 June 2012, 16:07 by Ant1981 »
Offline DunnDeal12
  • Limited
Re: lost key
« Reply #19 on: 25 June 2012, 16:17 »
how do you get in the car to do this?
