Author Topic: water/meth inj and power gasket= awesome!!!  (Read 3514 times)
Offline shaft69
« on: 16 June 2012, 16:24 »
Fitted power gasket yesterday massive difference on intake temp and adj timing using unisettings amazing performance pulls like hell. Advanced timing so far by 6degrees and still no pinking so still can go bit more.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: water/meth inj and power gasket= awesome!!!
« Reply #1 on: 16 June 2012, 16:37 »
How did you advance the timing?
Offline golf-sib
  • Турботазик
« Reply #2 on: 16 June 2012, 16:39 »
unisettings, but won't work for us AGU boys as its designed for ME7 systems, we use the bosch ME3.8.x systems
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline DunnDeal12
  • Limited
« Reply #3 on: 16 June 2012, 16:53 »
so the WMI is working now?
Offline shaft69
« Reply #4 on: 16 June 2012, 16:54 »
I used unisetting but lemmiwinks from revo can be used but with lemmiwinks need comms cable. Ordered maf based progressive controller, throttle spacer flange for 2nd nozzle from usrt in states going dual nozzle. Don't thing clutch going to last too long.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #5 on: 16 June 2012, 17:17 »
Yep all up and running brilliant, be even better when get proper controller. Only on/off pressure switch at moment not the best but it works ok, just comes in at 12psi.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline littco
« Reply #6 on: 16 June 2012, 17:26 »
Just fitting the power gasket didn't give you 6 degrees you must have been able to advance before fitting the gasket! Either way it's a good improvement. It would need to drop the iat quite a lot of 6 degrees. If you have it in the turbo you'd be better off upping the boost .
Offline littco
« Reply #7 on: 16 June 2012, 17:29 »
Ok may not have read the header sorry, wmi plus PG then yes I see 6 degrees. good work.
Up the boost.....
Offline DunnDeal12
  • Limited
« Reply #8 on: 16 June 2012, 17:45 »
i have a vernier pulley on my agu does that mean i can change the timing?
Offline golf-sib
  • Турботазик
« Reply #9 on: 16 June 2012, 17:56 »
Timing is electronic on the 1.8T, not like a distributor, so its software controlled which is how you advance it  :smiley:
1.8T AGU..
R135
  24
