Author Topic: Boost problem  (Read 2958 times)
Offline sebby1982
  • B16 SVP
Boost problem
« on: 13 June 2012, 20:40 »
Hi guys I have a 1.8t aum the problem I am getting is at about 3000rpm I'm loosing boost. It's intermitant sometimes she fly lovely and boost up good but other times it's like driving a standard 1.8, I have checked for leaks visually and it all seems fine the engine management light also comes on with codes p1602 which was voltage supply terminal low,30 voltage low?? Also code 6100 which I could not work out what that was. I had the codes erased twice but obviously it returned after about 100 miles. I was thinking that maby it's the n75 valve not allowing the actuator open so it could be faulty. If anyone knows of this problem please let me know. The most recent work I had done was my gearbox and clutch. The gearbox was a reconditioned one. Thank you guys
GOLF 1.8T AUM ENGINE, RECARO HEATED LEATHERS, FORGE 007 YELLOW SPRING DV, PIPERCROSS VIS INDUCTION KIT, 4 BAR PRESSURE REG, 2.50mm MILTEC DECAT PIPE AND NON RES CAT BACK, STAGE 2 REVO MAP (229.5 HP 268.6 LB/ ft @ 3813RPM), 18" INOVOTE DTM ALLOYS, CONTI SPT3 TYRES ALL ROUND, WEITEC COILOVERS, ANGEL EYES, DE BADGED, SMOOTHED ORIGINAL REAR BUMPER & R32 FRONT BUMPER, THS FRONT MOUNT INTERCOOLER, BLUE FORGE TIP AND WATER AND BREATHER PIPES, BOOST GAUGE, PRESSED PLATES
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #1 on: 14 June 2012, 11:15 »
just got fault codes looked at and there was 2 p1128 bank 1 mixture adaption (multi) system too lean, and code 3000 which had no explanation  :angry:
Offline Dalo Harkin
Re: Boost problem
« Reply #2 on: 14 June 2012, 13:11 »
Have you tried uplugging the MAF, and seeing if it runs better?
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #3 on: 14 June 2012, 20:09 »
No I have not the boost problem comes and gose than I get the management light every time a different fault code
Offline rio_gti
Re: Boost problem
« Reply #4 on: 14 June 2012, 20:51 »
N75 dodgy wire/connection??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost problem
« Reply #5 on: 14 June 2012, 22:01 »
my money is on split breather pipes
mixture too lean = air getting in somewhere
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #6 on: 14 June 2012, 22:42 »
I checked all breather pipes they seem ok going to check the decat pipe when I get a chance to put it in the ramp
Offline dan2252
Re: Boost problem
« Reply #7 on: 14 June 2012, 23:05 »
as this guys said. check for air leaks exhuast blow anything breather pipes. and that voltage fault your on about comes in when you let the battery run flat or take battery off
MK4 golf 1.8 turbo agu :)
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #8 on: 15 June 2012, 05:46 »
Thanks for your help guys
Offline Dalo Harkin
Re: Boost problem
« Reply #9 on: 15 June 2012, 08:53 »
Id still unplug the MAF and see if it runs better, failing that the pipe after the pancake pipe or on the plate where the N75 and N112 are
