Author Topic: Boost problem  (Read 2942 times)
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #10 on: 18 June 2012, 15:26 »
If I disconnect the maf sensor will it run worse than it is now? Another thing that came up was bank 1 regulation without was woundering what that was about as well
GOLF 1.8T AUM ENGINE, RECARO HEATED LEATHERS, FORGE 007 YELLOW SPRING DV, PIPERCROSS VIS INDUCTION KIT, 4 BAR PRESSURE REG, 2.50mm MILTEC DECAT PIPE AND NON RES CAT BACK, STAGE 2 REVO MAP (229.5 HP 268.6 LB/ ft @ 3813RPM), 18" INOVOTE DTM ALLOYS, CONTI SPT3 TYRES ALL ROUND, WEITEC COILOVERS, ANGEL EYES, DE BADGED, SMOOTHED ORIGINAL REAR BUMPER & R32 FRONT BUMPER, THS FRONT MOUNT INTERCOOLER, BLUE FORGE TIP AND WATER AND BREATHER PIPES, BOOST GAUGE, PRESSED PLATES
Offline Dalo Harkin
Re: Boost problem
« Reply #11 on: 18 June 2012, 15:45 »
If it is the MAF that is the problem, unplugging will make it better,if you unplug it and its worse then its not the MAF so plug it back in
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #12 on: 25 June 2012, 21:50 »
i disconnected the MAF and it was still boosting sh!t i think i am going to buy the n75 valve on thursday when i get paid
Offline sebby1982
  • B16 SVP
Re: Boost problem
« Reply #13 on: 30 June 2012, 20:27 »
I got a second hand n75 valve and reset the eml and the boost came back and worked well. I than left the car for an hour went to go for a spin and guess what no boost again after 3500 reves. I got a mate to rev my car while I looked under the bonnet and the actuator was not moving at all.
