Author Topic: Snow foam  (Read 5198 times)
Offline Ginge 35Edition
Snow foam
« on: 12 June 2012, 19:17 »
Can anyone recommend a snow foam product, I've just taken delivery of a new karcher and treated myself to their snow foam lance?
Cheers Ginge
Offline tech1889
  • Mk2 GTI FTW !!
Re: Snow foam
« Reply #1 on: 12 June 2012, 19:53 »
Why did you buy the karcher lance its gona be rubbish i imagine.. go on waxamomo and buy a proper lance a PH neutral snow foam
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Snow foam
« Reply #2 on: 12 June 2012, 20:10 »
TBH Snow foam is very hyped up anyhow, does not really do anything  more than what a decent blast with a decent pressure wash will do... i still snow foam myself tho as its fun  :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Bandit127
Re: Snow foam
« Reply #3 on: 12 June 2012, 20:13 »
That's a picture I don't want to have in my head...  :shocked:
Offline Mr GTD
Re: Snow foam
« Reply #4 on: 12 June 2012, 20:49 »
Offline Guy
Re: Snow foam
« Reply #5 on: 12 June 2012, 22:04 »
as a pre wash snow foam can be effective... but I have found TFR to be a better solution in the long run
Offline Mr GTD
Re: Snow foam
« Reply #6 on: 12 June 2012, 23:36 »
Guy, what's TFR?
Offline JC
  • Back in the North.
Re: Snow foam
« Reply #7 on: 12 June 2012, 23:40 »
traffic film remover  :wink:
comes in many varieties  :smiley:
Offline Ben Lessani
Re: Snow foam
« Reply #8 on: 13 June 2012, 00:10 »
I've never, ever been impressed by snow foam.
I've bought the lance from the group buy on DW - HD lance (something like that) and bought a gallon of SSP and Magic Foam (?) - can't remember the exact ones.
Long story short, it doesn't do much/anything. I've tried it on absolutely filthy cars to slightly dirty cars and have always had to resort to a hand-clean.
I bought it so that I could do a weekly touch-free wash, but it certainly won't ever replace a hand-wash, it does nothing!
... But as above, I still use it - it amuses me to fill the driveway with 2" thick foam.
Offline Dan J
Re: Snow foam
« Reply #9 on: 13 June 2012, 09:57 »
Snow foaming is purely designed to remove loose surface dirt not bonded contaminants, and isn't going to give you a touch less wash,
As has already been said you can just blow over with a pressure washer thoroughly which will remove a majority of nastys on the paint,
When making up my snow foam i use Autosmart active XL tfr in the mix which bumps the foaming up a bit and cleans very well though I would never use this method on a fully detailed and protected car.
for wax stripping I use diluted g101 through the lance.
@Mr GTD Tfr removes the traffic film ie diesel fumes,scum/dirt that accumulates over time and bonds to the paint if left, normal car shampoos can't remove this effectively as they are designed to be gentle.
« Last Edit: 13 June 2012, 16:37 by Dan J »
