Author Topic: Snow foam  (Read 5201 times)
MonkeyP
Re: Snow foam
« Reply #10 on: 13 June 2012, 15:01 »
Ive started using a company called Bilt-Hamber.
I use Surfex HD with my jet wash and then just give it a once over with car shampoo afterwards. I would also recommend their clay bar as it works with water so its a lot quicker!
http://www.bilthamber.com/
« Last Edit: 13 June 2012, 15:03 by MonkeyP »
Offline Mr GTD
Re: Snow foam
« Reply #11 on: 13 June 2012, 21:35 »
Snow foaming is purely designed to remove loose surface dirt not bonded contaminants, and isn't going to give you a touch less wash,
As has already been said you can just blow over with a pressure washer thoroughly which will remove a majority of nastys on the paint,
When making up my snow foam i use Autosmart active XL tfr in the mix which bumps the foaming up a bit and cleans very well though I would never use this method on a fully detailed and protected car.
for wax stripping I use diluted g101 through the lance.
@Mr GTD Tfr removes the traffic film ie diesel fumes,scum/dirt that accumulates over time and bonds to the paint if left, normal car shampoos can't remove this effectively as they are designed to be gentle.
Thanks for the expo...
