Author Topic: golf 1.8 t not getting going  (Read 1630 times)
Offline rageraver
« on: 11 June 2012, 23:18 »
hi, my golf 1.8 turbo with k04 -001 and intercooler dosent really feel turbo 'd intill 3.8k - 4k when it really gets goin and pulls like a train, it had no n75  valve when i got it, so i went scrapy and found n75 c valve fitted that and still the same.. want to get it boosting a bit lower if possible
Offline rageraver
Re: golf 1.8 t not getting going
« Reply #1 on: 11 June 2012, 23:35 »
it does start spooling around 2.2k but only like 4-5 psi not much pull then at 3.7-4k it hits full boost and goes and smokes my tyres
Offline rageraver
« Reply #2 on: 11 June 2012, 23:49 »
reading the forums it souds about right to be getting full boost around 4k, im only getting 11 psi tho, how can i get this up
Offline golfyste
  • Project track car
« Reply #3 on: 12 June 2012, 00:12 »
....take it to a proffesional tuner and get them to look at it. My k04-001 give full torque about 3000rpm
Offline AaronGS
« Reply #4 on: 12 June 2012, 09:14 »
As said in the other thread, it really needs looking at by a tuner to see if its software or hardware.
My Gt28rs is on full chat by then so would expect yours to be a bit sooner.
Your FMIC is very big though, is it not? That may create the lag you describe. Or it could be other hardware/piping issues that have not been found yet, or the actual map.
Or driving style, maybe?
Offline golfyste
  • Project track car
« Reply #5 on: 12 June 2012, 09:43 »
By the looks of the picture on the other thread it's one of them smaller eBay intercoolers like the toyosport etc nowhere near as big as the ths of forge cooled so I highly doubt that is causing the lag.
Offline AaronGS
« Reply #6 on: 12 June 2012, 11:51 »
Fair enough, couldn't quite remember what one it was and if it was small or disappeared up behind the crash bar! That eliminates one possibility then...
Offline rageraver
« Reply #7 on: 12 June 2012, 12:31 »
anything i can do to elimate sum stuff... wud pulling pipe of actuator do out...... i was told it had an econmy map... didnt believe it tho
Offline AaronGS
« Reply #8 on: 12 June 2012, 12:39 »
Who were you told provided the economy map? They are probably the best people to start with?
Offline golfyste
  • Project track car
« Reply #9 on: 12 June 2012, 12:51 »
That would only beig adding to the bodgery.
I take it to a pro turner who knows what they are doing. They joule be able to give you the low down.
Simply fiddling isn't gonna fix the problems.
