Author Topic: Look what Mr postman dropped off + info needed  (Read 1742 times)
Offline Chris#101
« on: 30 May 2012, 19:36 »
Finally had a chance to look through it all and it looks relatively straight forward to install  :cool:
 :cool:
Devils own 6-30psi WMI kit
50 liters of 99.95% Virgin grade methanol
Where would the injector/nozzle best be situated:
*BEFORE intercooler in pipe work!?
*AFTER intercooler in pipe work!?
*directly after the throttle body in the inlet manifold!?
*MIDDLE of the inlet manifold!?
Any guidance would much be appreciated  :smiley:
thanks
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline jonrandom
Re: Look what Mr postman dropped off + info needed
« Reply #1 on: 30 May 2012, 19:56 »
Looks good where did you get your methanol from?
You want to put the nozzle after the intercooler but its up to you where. Ive put mine in the pipework just after the intercooler for max time to mix with the air. Some people inject it straight in to the manifold and it works fine.
Dont know which is best up to you mate  :smiley:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 30 May 2012, 19:59 »
The only place I have ever seen it is on the manifold...Didn't even know you could put it anywhere else! :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 30 May 2012, 20:16 »
mine is tapped into the manifold just after the throttle butterfly  :smiley:
Would you like to get me some methanol and bring it to Inters  :wink:
Offline GTIcheeseman
« Reply #4 on: 30 May 2012, 21:05 »
is this tuff safe?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 May 2012, 21:23 »
not if you put a match near it  :grin:
« Reply #6 on: 30 May 2012, 21:34 »
How much? Is it legal?
Offline golfyste
  • Project track car
« Reply #7 on: 30 May 2012, 23:41 »
I had a chat with nick from r-tech about this and he reccomeded putting it after the intercooler before the map sensor (on a aum) as it mixes bette rand the map sensor re-adjusts if you run out of meth.
Don't quote me on this but pretty sure it's what he said best havin a chat with him  :cool:
Offline Toby
  • Car - less
« Reply #8 on: 31 May 2012, 08:18 »
I need this in my life
Currently down under
Offline golfyste
  • Project track car
« Reply #9 on: 31 May 2012, 08:19 »
I agree  :laugh:
