Author Topic: Look what Mr postman dropped off + info needed  (Read 1741 times)
Offline golfyste
  • Project track car
Re: Look what Mr postman dropped off + info needed
« Reply #10 on: 31 May 2012, 08:37 »
Want to be noses Christ of you don't mind  :grin:
Where did you purchase all the kit and meth and how much for??
Cheers pal  :cool:
Offline Chris#101
« Reply #11 on: 31 May 2012, 12:22 »
Cheers guys, Really looking forward to installing this  :evil:, apparently even before mapping the difference is noticeable  :cool:
I think il be tapping into the boost pipe after the FMIC then for the nozzle situ  :smiley: nice and out the way then  :laugh:.
As for prices etc
Bruce from http://www.methanol-injection.co.uk/ Sorted me out, He's a top bloke very helpfull and good after care Cost just shy of £300 inc postage, 6-30psi WMI kit & 4Quatrz tank  :cool:
As for the Methanol I searched high and low for the stuff untill I found a BIO fuel supplier just 10 miles up the road who sells 99.95%  Virgin grade methanol for just 80pence a litre   :cool:
Just had a quick skim through the electrical side of the brochure install..
What wire is the 12v ignition?
 :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline jonrandom
« Reply #12 on: 31 May 2012, 13:16 »
Luckly for yo the nearest place for me is leiester will have to pick some up on my way to rtech.
I just wired my WMI and EBC in and i used the little plug that conects to the gearbox right under the battery tray. There are two wires going to it and its the green/brown one off the top of my head but check it with a voltmeter, then it will go on and off with your ignition  :smiley:
Offline jonrandom
« Reply #13 on: 31 May 2012, 13:24 »
I put it in with a relay and a fuse just to be on the safe side  :wink:
