Author Topic: List of parts for a gti conversion  (Read 9923 times)
Offline madmanmart
Re: List of parts for a gti conversion
« Reply #30 on: 26 December 2012, 15:25 »
The chip in the key and the transponder box have to match and and they also have to be coded to the ECU.
So if you just swap the ECU then the car won't run but you can code your exsisting transponder and key to the new ECU with VAG-com
If you have the whole car then its easier to swap the whole lot.....
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline tweed
« Reply #31 on: 26 December 2012, 15:34 »
Where is the transponder box?
Offline GOLF-MK3-GTI
« Reply #32 on: 26 December 2012, 16:20 »
near the steering column, if you was to remove the stereo and air vents, you can see it.
Offline tweed
« Reply #33 on: 26 December 2012, 17:05 »
sweet
Offline murraymint
« Reply #34 on: 26 December 2012, 17:56 »
Yh it's a small black box with two wires going into it, one of the wires goes to the ring on the ignition barrel
josh
Offline ALTERNATOR
« Reply #35 on: 30 December 2012, 19:35 »
I've got a question related to this subject. I've got a 8v gti with heated seats and climatronic. I've been considering doing a 16v swap from a donor car. My only issue is will I be able to make the heated seats and climate control work? Or is it a question of modifying the 16v loom to accommodate these? :smiley:
Offline Screech16v
  • MK3 20vt AGU
« Reply #36 on: 30 December 2012, 19:46 »
You shouldn't have to touch them parts of the looms just the engine side
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #37 on: 30 December 2012, 20:36 »
Should be fine.
Offline ALTERNATOR
« Reply #38 on: 01 January 2013, 19:21 »
Great!  :grin:
Thanks allot man! :smiley:
Offline 67buggers
« Reply #39 on: 01 January 2013, 20:01 »
Check you out with your climatronic..... Jealous!
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
