Author Topic: changing abs ecu ?  (Read 9352 times)
Offline Screech16v
  • MK3 20vt AGU
Re: changing abs ecu ?
« Reply #30 on: 30 July 2012, 21:24 »
You have a known working pump and ecu as a pair not on the car non? put it on bleed the brakes youll be fine  :undecided:  :smiley:
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #31 on: 30 July 2012, 21:31 »
well it was sold as being said it was working yes so i thought i'd try the ecu first so i have taken the ecu off the new pump and stuck it on my original pump to which there is no change in the codes coming up so only option really is to see if tshirt can find a problem with my original ecu if there are no problems then it is definately the pump so i will have to try the new pump anyway  :sad: i cant see why it wouldn't bleed up the normal way myself with matching ecu and pump like you say should I try it?
Offline Screech16v
  • MK3 20vt AGU
« Reply #32 on: 30 July 2012, 21:54 »
Mate i would just go for it ,does your abs work at all ,now and again?
  • my golf gti mk3
« Reply #33 on: 30 July 2012, 22:06 »
yeah if the handbrake lights on it works almost fine but if its off then it hardly works at all  :sad: might just do that once i get ecu back lol
Offline tshirt2k
  • Been there...Done that...
« Reply #34 on: 30 July 2012, 22:22 »
Handbrake light? That means bias isn't working.
Mk3 ABF 16VT Megasquirt V3
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #35 on: 30 July 2012, 22:29 »
My handbrake light comes on after a couple of minutes and then stays on. So then I guess I need to repair the abs ECU then?
95 Volvo 480 2.0 Celebration
Offline tshirt2k
« Reply #36 on: 30 July 2012, 22:32 »
Don't brake to hard. You may find rear will lock up.
  • my golf gti mk3
« Reply #37 on: 30 July 2012, 22:33 »
yeah could be back end locks up sometimes getting used to it now  :sad: what does that involve so it might not actually be the main pump after all? bloody vw  :sad:
this is what mine does but sometimes it wont come on for half a mile or so which is when its most dangerous as i have hardly no brakes  :angry:
Offline Screech16v
  • MK3 20vt AGU
« Reply #38 on: 30 July 2012, 22:34 »
This is what mine was doing coupled with the abs light,ECU was at fault.
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #39 on: 30 July 2012, 22:36 »
It has been locking up on loose surfaces like on a dusty road and the front end has tried to jump into the hedge!
