Author Topic: changing abs ecu ?  (Read 9347 times)
Offline Stewy12
Re: changing abs ecu ?
« Reply #20 on: 14 June 2012, 07:36 »
If u got vagcom you can do a test on the pump if u need a pump i got a spare and ecu as i bought a couple when my went and all been tested..
Offline Screech16v
  • MK3 20vt AGU
« Reply #21 on: 30 June 2012, 00:14 »
Well after nearly two years mostly in the company of the abs light,it has now finally been extinguised, hoo f--kin ray,
Tshirt2k worked his electronical witchcraft on my abs module and sorted it,top bloke and does a quality job too .One is most pleased  :smiley:
Offline lemski
  • 16v
« Reply #22 on: 30 June 2012, 10:19 »
Mike bring it down mate, av got full vag com so can check it all. Well bleed the system up at the same time if you want aswell buddy. You know where I am
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #23 on: 01 July 2012, 15:17 »
nice job  :smiley: think i'l send tshirt my spare ecu then  :smiley:
Cheers liam i'm on shift this week so might be able to get down to you one morning this week  :smiley:
Offline lemski
  • 16v
« Reply #24 on: 01 July 2012, 17:52 »
Just giz a txt when mate and well scan it see what's going down. U may have to code the pump to ecu aswell. Gd job I've got vag com
  • my golf gti mk3
« Reply #25 on: 30 July 2012, 19:53 »
really need to get this sorted now  :sad: couldn't be fixed with vag com  :sad:
Offline Screech16v
  • MK3 20vt AGU
« Reply #26 on: 30 July 2012, 21:04 »
Mines still working mint  :smug: PM tshirt im sure he will sort it mate.
  • my golf gti mk3
« Reply #27 on: 30 July 2012, 21:09 »
sounds good :D i just have messaged him he's off on holiday he said send it in few weeks i'm still sure its my actual pump though  :sad: cheers
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #28 on: 30 July 2012, 21:14 »
I had my complete abs system off the car, and in bits to clean and paint, Refitted and bled the brakes using the usual method and worked great, no codes or abs light and no vagcom needed. Only think you need it if you have changed the pump from another car.
  • my golf gti mk3
« Reply #29 on: 30 July 2012, 21:19 »
Sounds good although my problem may just be that i'm looking to replace my pump with another second hand unit to see if the pump is infact the problem. I am thinking now though if thats the case with the pump then surely it would be with the ecu ? I can't find a definative answer anywhere  :sad: i don't mind bleeding brakes etc but i'm worried i'm going to stuff this up if i swap the pumps over and it won't bleed or something  :sad:
