Author Topic: changing abs ecu ?  (Read 9351 times)
Offline Screech16v
  • MK3 20vt AGU
Re: changing abs ecu ?
« Reply #40 on: 30 July 2012, 22:43 »
Handbrake light? That means bias isn't working.
yeah could be back end locks up sometimes getting used to it now  :sad: what does that involve so it might not actually be the main pump after all? bloody vw  :sad:
My handbrake light comes on after a couple of minutes and then stays on. So then I guess I need to repair the abs ECU then?
this is what mine does but sometimes it wont come on for half a mile or so which is when its most dangerous as i have hardly no brakes  :angry:
Yours really does seem to point towards ecu  seeing as its making your brakes not work,i would try driving with it unplugged until you do the job at least then the ecu cant tell the pump to kick in stopping you from braking as normal.
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #41 on: 30 July 2012, 22:48 »
sounds like a plan does that work lol will basically be like no abs I take it? but will hopefully not try to kill me all the time  :smiley:
Offline tshirt2k
  • Been there...Done that...
« Reply #42 on: 30 July 2012, 22:50 »
A failed ecu won't cause brakes not to work. It will just not control pressure applied to front and rear wheels.
ABS light tells you ABS has a fault and it's disabled. If handbrake light is on too I'd be very careful when driving. Rear will try to overtake front if you brake hard as weight shifts forward and off rear wheels.
Unplugging abs will be the same. It won't help you much.
Mk3 ABF 16VT Megasquirt V3
Offline AcidicDavey
  • Not a VAG Owner.
« Reply #43 on: 30 July 2012, 22:53 »
How much are we looking at for an ECU repair?
Would I need the light on the dash reset or would it sort it itself?
95 Volvo 480 2.0 Celebration
  • my golf gti mk3
« Reply #44 on: 30 July 2012, 22:54 »
The later is my problem i need to sort this asap MOT in october  :sad:
Offline tshirt2k
« Reply #45 on: 30 July 2012, 22:58 »
Bba charge around £200. Pm me. I should be able to sort you out after my holiday.
Offline Screech16v
  • MK3 20vt AGU
« Reply #46 on: 30 July 2012, 23:01 »
When i say it causeing the brakes not to work,i think the ecu is controlling the pressure applied but for mikes case its stopping him from braking sometimes as if the abs is kicking in in a non abs situation ,mine did this some times no matter how hard i pressed the pedal it would not let me stop quickly and nearly shot out of a couple of junctions,this stopped when ecu was unplugged but as said brake bias will not work.
Offline tshirt2k
« Reply #47 on: 30 July 2012, 23:08 »
Ok yea I get ya. Sometimes,  Abs pump will operate too when brake pedal not even pressed.
