Author Topic: 1.4 to gti conversion  (Read 7238 times)
Offline murraymint
Re: 1.4 to gti conversion
« Reply #20 on: 22 May 2012, 17:46 »
I reckon with two people you'd have an ABF running in a late MK3 (late cause pedal box).
Then the next day you'd have it finished.
How can you tell if your mk3 is an early or late model? As mine is a let 95 model but had square indicators
josh
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #21 on: 22 May 2012, 18:28 »
Yes but after you declare it insurance will probably be more given the nature of engine conversions
Actually quite possibly not.  Insurance companies tend to take an average of the insurance group, so it may well be lower than a standard GTI.
Hardly worth the effort though.
they class it as a modification.. it will go up more.. id deffo check first
we have had issues, not quite the same but..
direct line and about 15 other companies wouldn't insure my dads car no longer because we converted it to AUQ (180 BHP mk4 Annie engine and box)) from 2.0 8v
the only company that would touch it was Adrian flux, however the price was same as he was paying on the 2.0 engine
I also had the same problem when i did mine, as did my mate whoc mk4 we converted from 1.8 non turbo to 1.8T
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #22 on: 22 May 2012, 18:29 »
will be late, they have bigger brakes (usually - not always)
biggest tell tale is the clocks tho, show me a pic of your clocks and ill tell u
also where is the diagnostic port ?
Offline murraymint
« Reply #23 on: 22 May 2012, 18:33 »
The diagnostic port is next to the ashtray/ cig lighter
« Last Edit: 22 May 2012, 18:36 by murraymint »
josh
Offline murraymint
« Reply #24 on: 22 May 2012, 18:35 »
Clocks
josh
Offline F17BAD
« Reply #25 on: 22 May 2012, 19:03 »
thats late spec mate
Offline murraymint
« Reply #26 on: 22 May 2012, 19:23 »
Cheers for that :afro: good to know  :smiley:
josh
Offline F17BAD
« Reply #27 on: 22 May 2012, 19:24 »
no probs dude :smiley:
Offline stainesy
« Reply #28 on: 22 May 2012, 19:25 »
thats same clocks as mine and i have square wing indicators so does that mean mine a late one aswell? i thought it was early due to the indicators
Offline F17BAD
« Reply #29 on: 22 May 2012, 19:33 »
yeah will be late
forget indicators shape it means naff all, even bens late spec had early spec brakes (280's) but had oval indicators
