Author Topic: 1.4 to gti conversion  (Read 7236 times)
Offline Willo
« on: 22 May 2012, 11:08 »
I know this has probably been asked a million times but what parts will I need to the conversion so I can start a shopping list my car is an 8v 1.4 on a m plate
Will
Re: 1.4 to gti conversion
« Reply #1 on: 22 May 2012, 11:09 »
Sell it and buy a GTI, so much needs changing it is not worth thinking about.
Offline Bellend
« Reply #2 on: 22 May 2012, 11:14 »
8v will be engine, loom, ECU. Loom goes straight in the fuse box. Then clocks and immob box, fuel pump gearbox.
Not too hard if you just drop the subframe, change the looms and clocks and box.
Can do it with dash in. Then stalks as well.
Where all my moneys went.
Offline Bellend
« Reply #3 on: 22 May 2012, 11:19 »
Actually, for 8v:
- Engine, gearbox and all parts associated such as starter, alternator, clutch etc
- Slam panel and radiator
- ECU
- Engine Loom
- Clocks, stalks and associated looms
- Immob box and loom
- Fuel pump
Think that's it.
For 16v add on clutch cylinder, brake resovoir & piping, and possible pedal box if yours is an early one.
Offline Willo
« Reply #4 on: 22 May 2012, 11:29 »
So it's only really worth doing if I can get a cheap donar car by the look of things whats the bhp on a gti 8v
Offline trog_nfs
« Reply #5 on: 22 May 2012, 11:30 »
115 bhp
« Reply #6 on: 22 May 2012, 11:36 »
Your also going to need to uprate the brakes and it might be worth checking insurance first.
Offline Willo
« Reply #7 on: 22 May 2012, 12:28 »
Insurance is cheaper than on a gti by nearly 500 I'll keep a open mind for now as was just an idea for now
Offline trog_nfs
« Reply #8 on: 22 May 2012, 12:47 »
Yes but after you declare it insurance will probably be more given the nature of engine conversions
Offline search
« Reply #9 on: 22 May 2012, 12:49 »
best off buying a GTi.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
