Author Topic: Cambelt Tensioner damper  (Read 1511 times)
Offline paultownsend
« on: 20 May 2012, 21:29 »
Good evening all
Next week I'm getting my cambelt and waterpump done. The car is a 90k old 1.8t.
The car had it's last major service at Vw. But it made no mention of the Cambelt Tensioner damper.
The parts I am using are all VW tps items. Does the Tensioner damper need to be done at the sane time?
I will be going through AVS and the item is an INA. Is this decent OE quality?
Also, what exactly does this famed do? As the Vw kit already comes with a roller?
Paul
Offline theshrew
Re: Cambelt Tensioner damper
« Reply #1 on: 20 May 2012, 23:54 »
If your doing your cam belt its a good idea to do your water pump at the same time if its not already been done as its a common problem.
I always go by doing your belt do the tensiioner to.
Offline fishfingerface
« Reply #2 on: 21 May 2012, 10:11 »
This kit looks good
ECS Tuning Ultimate Timing Belt Kit - 1.8T 150/180/225
http://www.psituning.com/product.php/19143/ecs_tuning_ultimate_timing_belt_kit___1_8t_150_180_225
I this the ideal cambelt kit?
seems expensive at £174
Offline bunj
  • www.bunjair.com
« Reply #3 on: 22 May 2012, 08:42 »
You should get the idler and tensioner pulley in the cambelt kit.
I would'nt dream of changing a cambelt with doing the tensioner...
MK4 GTi 1.8T, Black magic, stage one Jabba, Forge Split, filter, sportex race pipe, lowered 25mm.
PS3 network: raebuns
Offline shaft69
« Reply #4 on: 22 May 2012, 17:53 »
Good evening all
Paul
My mate works at vw and he never fits damper ever or very rarely, do get tensioner and idler in kit. INA oem kit spot on.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 23 May 2012, 19:25 »
tensioner is worth doing IMO, if that goes it will do some serious damage, and all for the sake of £40 odd
« Reply #6 on: 23 May 2012, 19:38 »
done! INA from AVS. they make good bearings and more than half the price of vw. all other bits are from TPS. there doing synta platinum and a filter for £20!
