Author Topic: Welding!  (Read 2130 times)
Offline Lewizkid
Welding!
« on: 08 June 2005, 11:24 »
Will my car ever be what i want it to be?!!!!!! Driving me nuts, i know it's 22 years old but some owners have obviously neglected it over time. I've done so much to it since i got it in October. Just had my garage check over bits to be welded. I knew of the rear arch n spare wheel well but they found that the clutch was cuttin through the bulkhead :( God knows what its going to cost me. For some reason though i can't see myself giving up on Douglas!
Anyone else get these doubts about mk1s, there's no car quite like em but that inlcudes the maintanence! Hard work. Well worth. MOT due sept so lets hope its in good shape for then.
Also does anyone know what prices id be looking at for a gear box refurb? Id rather not think about it but it may be in the pipeline so to speak.
Anyway rant over.
Lewis.
Offline gibby
Re: Welding!
« Reply #1 on: 08 June 2005, 11:52 »
It's a common problem is the clutch cable cuttin through the bulk head, mine went on me about 6 months ago and snapped the cable, but it should only be a minor piece of welding, it's where it is that wil be the ballache for them. If possible try to get them to put a rubber washer to feed the cable through so it doesn't snap again when rubbing through the hole. As for the gearbox, I don't know prices but a reconditioned gearbox shouldn't be stupid money, I guess the labour of fitting it will eat most of the cash.  :undecided:
I get miffed with my cabby from time to time but when I see it nice and shiney, clean and running well, I love it.  :grin: So just hang in there, you know it makes sense.  :wink:
......now officially dubless.
Offline mk1
Re: Welding!
« Reply #2 on: 08 June 2005, 22:25 »
If the clutch cable pulls thru the bulkhead there is a modified plate from VW that sticks to the bulkhead to strengthen the area. Check the clutch and cable are good as if they are worn and make the clutch heavy, and this can cause the problem.
Steve.
mix
Re: Welding!
« Reply #3 on: 08 June 2005, 22:35 »
Gimme a welder and its done for ya :evil:
And i learnt how to do that at uni and it wasnt because i broke my house (not that i did that :huh: )
Offline Lewizkid
Re: Welding!
« Reply #4 on: 09 June 2005, 17:15 »
Yeh the cars already had a repair plate n even thats gonna have to be replaced and welded properly.  :angry: My clutch is as heavy as a very fat person, but assumed all this time that was pretty normal as my mk1 polo use to be the same. Ahh well, bring on the welding. Lucky ive got a spair clutch cable lying about may as well get that replaced at the same time. Then the gearbox, then the oil leak. Then the bubbling. Then the repsray. Where will it end!?!!
Offline richard ellison
  • Mk1 Cab 'Gertrude'
Re: Welding!
« Reply #5 on: 09 June 2005, 19:56 »
I think the main adjustment youre going to have to make mentally is that a mk1 cannot run without regular maintenance and parts- speaking from experience after shelling out over a grand last time it needed work.
Shop around for a welder, i got stung.
mix
Re: Welding!
« Reply #6 on: 09 June 2005, 20:40 »
Im telling ya, someone goves me a welders i'll join ya doors up do anything you need
(mix has soem uses......)
Offline Lewizkid
Re: Welding!
« Reply #7 on: 10 June 2005, 16:01 »
Hehe if i had a welder thingy id let you do it mix. Obviously you'd have to practice on the bmw that always pinches my parking space  :wink:
Recommended a bloke by the garage i use so il get a quote and let you know if thieves only steal from houses.
Rick - give us a shout when you're back so i can steal help you put your single grill on.  :grin:
mix
Re: Welding!
« Reply #8 on: 10 June 2005, 21:25 »
One Zero door coming up :laugh:
Offline Redbaron
Re: Welding!
« Reply #9 on: 13 June 2005, 21:34 »
Pish
Ive had my mk1 a year and still havent even driven it!
Talk about depression, its in the garage with no wheels or even a ream beam on it.
Everytime i complete one job i find something else wrong.
one day ill finish it.
Bloody mk1's  :angry:
