Author Topic: AGU Engine Mis-fire When engine is hot...advice needed  (Read 2647 times)
Offline fishfingerface
Hi All
i'm a newbie and need  some advice on my 1999 AGU Golf 1.8T
The car seems to mis-fire badly when it gets hot....
Its had a code reader plug into it and nothing shows...i have changed he Igntion control Unit by the Air box...thinking that was it
am i right in saying it could now be the Coil packs....it seems odd that nothing shows on a fault code reader...
the car seem to splutter then cut out...this could happen on a junction and with my baby girl onboard this is not good
any help or advice would be great
« Last Edit: 14 May 2012, 13:15 by fishfingerface »
Re: AUQ Engine Mis-fire When engine is hot...advice needed
« Reply #1 on: 14 May 2012, 13:11 »
AGU ENGINE CODE
« Last Edit: 14 May 2012, 13:13 by fishfingerface »
Offline Toby
  • Car - less
Re: AGU Engine Mis-fire When engine is hot...advice needed
« Reply #2 on: 14 May 2012, 13:15 »
Ignition amplifier on your air box is usually the culprit, unlike ye coils to go on a agu
Currently down under
Offline Granta Gti
« Reply #3 on: 14 May 2012, 13:16 »
Try changing plugs  :wink:
« Reply #4 on: 14 May 2012, 13:48 »
I have changed the ingnition amplifier back last week..but this didn't sort out the misfire when hot
Offline BarryMKIV
« Reply #5 on: 14 May 2012, 13:57 »
Have you had it scanned yet?
25th Anniversary GTI 1.8T No. 0441
Offline richw911
« Reply #6 on: 14 May 2012, 14:00 »
No codes could mean the MAF sensor  :smiley:
Offline xxChrisxx
« Reply #7 on: 14 May 2012, 14:26 »
Pointless doing a scan on an AGU as nothing ever shows up. Better to do it the old fashioned way. :nerd:.
Doing it when hot, I would say fuelling rather than spark.
1. Whip the plugs out and see what they look like.
2. Clean the throttle body, if it hunts for idle even remotely.
3. Use some injector cleaner, and give it a run.
4. Unplug the MAF and try to replicate the problem. It may run worse, but if it stops the cutting out it's a fault with the ECU diddling with fuel trims, not necessarily a duff MAF.
5. Check for air leaks.
If you know someone with a copy of VAGCOM do a log of the air flow values.
« Last Edit: 14 May 2012, 14:29 by xxChrisxx »
Offline km
« Reply #8 on: 14 May 2012, 14:41 »
my car used to misfire and cut out an awful lot. a new maf sorted it!
Offline xxChrisxx
« Reply #9 on: 14 May 2012, 14:53 »
People needlessly changing MAFs at £80 a throw (or whatever it is) has to be one of the biggest earners for Bosch.
It's money for old rope; recon it by giving it a little wipe down.
