Author Topic: AGU Engine Mis-fire When engine is hot...advice needed  (Read 2658 times)
Offline fishfingerface
Re: AGU Engine Mis-fire When engine is hot...advice needed
« Reply #20 on: 17 May 2012, 14:15 »
This is a pig of a Fault
do really want to start changing loads of stuff and it still dosen't fix it...there has to be someone who has had this and sorted
we just need a quick answer.....
inggti...i'm the same as you..........had a right scare the other day...slowing down to turn left onto a side road with cars right behind me the F**king car decides to stall
two cars nearly plough into the back of me
Offline Granta Gti
« Reply #21 on: 17 May 2012, 14:20 »
What have you done/ changed so far?
Offline richw911
« Reply #22 on: 17 May 2012, 15:31 »
As above what have you done so far?
Was the temp sender a Genuine part? Are the plugs new / OK?
It could be a coil pack AGU coils don't usually go but they can
Have you cleaned the throttle body as suggested?
With a faulty Crank sensor you usually cant start the car when it is warm.
Offline inggti
« Reply #23 on: 18 May 2012, 13:16 »
Sort to jump in. I've changed ignition amp coil packs temp sensor. And still the same oh yes and lamba sensor. Yesterday had it pluged into snap on machine and it came up throttle position sensor. And it's getting harder and harder to start over the last few days. Thinking about new crank and cam sensor next. After that who knows. Anubody
