Author Topic: AGU Engine Mis-fire When engine is hot...advice needed  (Read 2663 times)
Offline richw911
Re: AGU Engine Mis-fire When engine is hot...advice needed
« Reply #10 on: 14 May 2012, 14:57 »
People needlessly changing MAFs at £80 a throw (or whatever it is) has to be one of the biggest earners for Bosch.
It's money for old rope; recon it by giving it a little wipe down.
From experience of people cleaning it only delays the inevitable  :wink:
Offline xxChrisxx
« Reply #11 on: 14 May 2012, 15:08 »
But for the amount of people that have changed it when it's something else screwing up the fuelling.
Offline richw911
« Reply #12 on: 14 May 2012, 15:21 »
Ah I see what you mean indeed I agree check the basics first  :smiley:
Offline fishfingerface
« Reply #13 on: 14 May 2012, 15:26 »
so first port of call is.................
Clean the Maf Sensor
Possible plug change
Offline xxChrisxx
« Reply #14 on: 14 May 2012, 15:37 »
Check the plugs.
It'll tell you a huge amount about whats going on in the cylinder. It'll give you a good indication why you are getting poor combustion.
Clean the throttle body.
It'll stop any hunting for idle, and is free.
Check for vac leaks, specfically on the PCV system hoses to the inlet manifold and the breather pipe.
Unplugging the MAF makes the engine fuel on a default map, as it doesn't know how much air it's getting.
If you don't start to misfire when you get up to temperature you know it's something that messing up the fuelling.
« Reply #15 on: 14 May 2012, 15:40 »
Thank you  Chris
Offline inggti
« Reply #16 on: 14 May 2012, 18:05 »
I've got this problem with my agu. The past four weeks the only code that came up was temp sensor. After changing that still the same just come bak from we're I had it remapped and I know now the culprit is tha lamba sensor it only showed up wen the remap man did a live scan and the sensor reading was all over the place. So new lamba tomorrow and then bak to sort remap out
« Reply #17 on: 16 May 2012, 10:47 »
Hmmm Interesting  :wink:
Offline inggti
« Reply #18 on: 17 May 2012, 12:59 »
Ok still got the same problem. Even changed lamba sensor.  Any ideas before I scrap it
Offline harlemex
« Reply #19 on: 17 May 2012, 13:13 »
Agreed with Chris on the maf sensor. Loads of people shell out for the miracle maf sensor cure and its a waste of money. My guess is the camshaft sensor.  :tongue:
