Author Topic: tyres rubbing  (Read 2117 times)
Offline albertsponge
tyres rubbing
« on: 02 May 2012, 19:56 »
hi, im new on here,was with a subaru club,now got me a 2000 gti turbo,
i think it has 18inch rs6 5 spoke alloys? on full lock the wheels scrape.
tyres are 225/45/18  love the wheels but cant do with scraping all the time,
any advice thank you, and hello :smiley:
« Last Edit: 02 May 2012, 20:14 by albertsponge »
Offline daz veedub
  • Operation 1.8t bolf
Re: tyres rubbbing
« Reply #1 on: 02 May 2012, 20:00 »
is it lowered if so will more than likely be the anti roll bar rubbing on driveshaft uprated arb needed like the mk1 audi tt which goes under rather than over the driveshaft
also 225/40/18 is normally the tyre used
Re: tyres rubbbing
« Reply #2 on: 02 May 2012, 20:11 »
thanks, not lowered  :sad:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: tyres rubbing
« Reply #3 on: 02 May 2012, 20:54 »
I would say you should almost definitely not rub with that set up...Strange.  :undecided:
Re: tyres rubbing
« Reply #4 on: 02 May 2012, 21:44 »
Are they direct fit or running adaptors
Re: tyres rubbing
« Reply #5 on: 03 May 2012, 18:28 »
it is lowered phew! i'll change the wheels :sad:
Offline mcgee9t2
Re: tyres rubbing
« Reply #6 on: 03 May 2012, 18:39 »
how much is it rubbing, could try putting a bit of streach on the tyres?
also take one wheel off and look at driveshaft, see if the arb is rubbing on it, that could be the cause of the rubbing, if so Clicky or raise the car up a little
Re: tyres rubbing
« Reply #7 on: 03 May 2012, 18:57 »
these are the wheels,i'll have a look what they are rubbing on, 225/45/18
Offline mcgee9t2
Re: tyres rubbing
« Reply #8 on: 03 May 2012, 19:03 »
ive seen golfs running them before, so could be the arb as said. was actually going to get a set for my car before i got the current alloys.
Re: tyres rubbing
« Reply #9 on: 03 May 2012, 19:09 »
hi pal what alloys are they? which arb should i be looking at thanks :wink:
